GeneralT001 Posted November 10 Posted November 10 What do you guys/gals do to get an engine? Can you recommend one place over another? I believe a brand new engine is significantly more expensive than a rebuilt? Is it even possible to get an engine nowadays? Quote
Kent Ashton Posted November 14 Posted November 14 Yep, new Lycoming engines are hugely expensive. If I were buying an engine today I would monitor aircraft salvage companies and look for a medium-time engine from a wrecked airplane. There are probably salvage companies in Europe but I don't know them. Some of the planes they get are storm-damaged so the engine is probably intact. https://www.wentworthaircraft.com/engines/ I imagine their inventory goes up every time there is a hurricane in the U.S. 20 years ago I got a good price on an engine from https://www.aerosportpower.com/custom-aircraft-engines It had a reconditioned case, new cam, crank and cylinders. It is good to understand the different models and know whether you want one with mags and a carb or you will supply your own electronic ignitions and fuel system. https://en.wikipedia.org/wiki/Lycoming_Engines I rebuilt a run-out Lycoming once. I sent the cases to Divco and the metal parts to Aircraft Specialties and put it together myself. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold
