The plans for cozy shows a piece of foam 42" x 28.8" to be glassed with 2 plys, the orientation angle is not explicitly mentioned but if I assumed 45 degrees the part will not fit the 38" wide roll. In order to fit the angle has to be a lot shallower on both plys, is that the intention?
It is meant to be 45 degrees. You'll just need to use more UNI for these situations. Check Chapter 3 for whether the plies should be overlapped or butted.
