Sales I've seen
Seen today.  Nice repair job on the fuselage.  The original finish appears to be the black UV-blocking primer that was recommended in the early days--that stuff did not stick well but is easy to sand off (in my experience).  Some earlier intel here   https://www.canardzone.com/forums/topic/21972-sales-ive-seen/?do=findComment&comment=66835
Today's B-stormers:  No pics.  N35PC   http://www.aviationdb.com/Aviation/Aircraft/3/N35PC.shtm
Quote
VARIEZE • $38,000 • FOR SALE TO GOOD HOME • Great flying Varieze,Low time O-200. this is your grandfathers airplane,thats why it flys so well. • Contact Gil Hutchison , Owner - located Salem , OR United States Telephone: 503 510 2317 • Posted April 11, 2022
Selling my extra Lightspeed Plasma (original version).   I upgraded to Plasma IIIs.  It would work well paired with a magneto, paired with another Plasma, or kept as a spare.  It comes with the manual and wiring diagrams. To use this Plasma, you would need Lightspeed's Hall Effect trigger or either of Lightspeed crank-sensor systems like the Mini-Sensor or the green ring. This Plasma is marked "Hall Effect" but per confirmation from Lightspeed, it works with any of the three trigger systems.  To complete the installation you would need two coils, two RG-400 cables with female BNC connectors, some twisted-pair wire, a 25-pin D-sub and crimp pins, quality plug wires and 18mm auto plugs (Autolite 386, for example) or 14mm Denso/NGK plugs with inserts. The mag-hole Hall Effect sensor is your easiest option.  Klaus checked it last Fall and says it works perfectly.
In operation, these are indistinguishable from the latest model Plasmas. The newer models have some timing-control and monitor options which are not required unless you feel you need to monitor the timing, otherwise they are all good ignitions, easy to setup and time and offer noticeably better cruise performance than a mag. With the Hall Effect trigger, timing is a matter of setting the engine on TDC and rotating the sensor until a green light comes on. You're timed.
See www.lightspeed-aero.com   PM me if interested
Quote
LIGHTSPEED PLASMA IGNITION • $520 • FOR SALE • 4-cyl Lightspeed Plasma I EI. Checked by mfg. Pics and details upon request. Includes shipping. • Contact Kent Ashton , Owner - located Concord, NC United States Telephone: 704-784-1874 • Posted April 17, 2022
A Cozy Mk IV for $119k: https://www.trade-a-plane.com/search?category_level1=Single+Engine+Piston&make=CO-Z+DEVELOPMENT+CORP&model=COZY+MARK+IV&listing_id=2404253&s-type=aircraft  More pics at the listing
150-175kt TAS with 6.5-8.5 GPH; 52 gal usable fuel make this machine extremely capable with an effective range of 1200nm.
A Garmin G3X 10.5 inch screen as a PFD and a GFC 500 digital autopilot, coupled to a GTN 625 for navigation and MFD create this state of the art cockpit that not only is FULL IFR but also allows for safe VFR flights with live traffic and weather alerts.
A newly installed Surefly Electronic Ignition Module provides a clean reliable spark on every stroke of the engine, making starts easy in any condition and a smooth and efficient cruise performance.
Quote
eyJidWNrZXQiOiJ0YXAtYXNzZXRzMSIsImVkaXRzeyJidWNrZXQiOiJ0YXAtYXNzZXRzMSIsImVkaXRz
A project and a finished plane showed up on Barnstormers:
Quote
LONG EZ PROJECT • $18,000 • AVAILABLE FOR SALE • Approximately 70% completed. 140hp Lycoming O-290-D2, 685hrs. With prop, instruments, and instructions. Aircraft is in Denver, Colorado. • Contact Leon Edling - CB560 , - located Colorado Springs, CO 80922 United States Telephone: 17193512645 • Posted April 18, 2022
thumbnail_image_1732910_1_1650300544.jpeg?7869 thumbnail_image_1732910_1_1650300543.jpeg?2023 thumbnail_image_1732910_3_1650300546.jpeg?7702 thumbnail_image_1732910_4_1650301233.jpeg?8494 thumbnail_image_1732910_5_1650301234.jpeg?832
LONG-EZ • $29,000 • ACCEPTING OFFERS • Long-EZ O-235 Lyc.1638 hrs TT, Cato prop electronic ignition, electric NG, Escort2 navcom • Contact William French , Owner - located Lisbon, NH 03585 United States Telephone: 802 881 2333 • Posted April 17, 2022
Today:
Quote
COZY IV WING AND WINGLET CORES • $2,400 • AVAILABLE • Eureka CNC Cozy Mk IV wing and winglet cores for sale. Eureka CNC is closing up shop indefinitely. This is a set of cores I had in storage. They have a few minor dings from being in storage that are easily repairable using normal Rutan building practices. They are discounted $1000 from the normal price. I can also offer to include a newly cut set of Cozy IV canard cores if needed for an additional $600. I may even be able to offer delivery in some areas. If unable, they can be shipped FedEx. • Contact Steve James , - located Alamogordo, NM 88310 United States Telephone: 702 416-8729 • Posted April 20, 2022 •
COZY IV WINGS • $5,000 • AVAILABLE • Cozy Mk IV wings complete through wing skins. Not yet drilled. No winglets are attached for ease of shipping and storage. These were built by a professional builder using Eureka CNC foam cores. These wings have straight trailing edges and extended ailerons. • Contact Steve James , - located Alamogordo, NM 88310 United States Telephone: 702 416-8729 • Posted April 20, 2022
and  this one,  N511EZ.  Nice looking airplane  (pics)
Quote
VARI-EZE / FAST & EFFICIENT! • $35,000 • AVAILABLE FOR SALE • Fast, fun, and efficient aircraft. Max performance, 196mph burning 5.7gph. Will deliver for expenses. Due to fast approach speeds and loads, this aircraft is recommended for experienced/talented pilots under 210lbs. Full spec sheet available.VARI-EZE SALE SHEET • Contact Britton Shaw , Owner - located Fort Smith, AR 72908 United States Telephone: 4796296184 • Posted April 19, 2022
A couple of Long EZ's:
Quote
LONG-EZ N64MC • $49,000 • FOR SALE BY PROUD OWNER • + Total time 1750 hrs. Empty weight 1088 pounds + Engine O-320, 1537 hrs SMOH + Top overhaul by Ly-Con, 110 hours ago New cylinder assemblies, port flowed, new valves + Electronic Ignition: + Catto Propeller 3-blade + Autopilot: Trio Pro-pilot + Terra comm, nav & transponder; recent IRAN, latest digital displays + ADS-B In and Out + Cabin heater; Electric nose gear; Vortex generators(Jim Price design) + Currently flyable, Hangared: O32, Reedley, California (near Fresno) + Leave voicemail message • Contact Bruce McElhoe , Owner - located Reedley, CA 93654 United States Telephone: 559-859-6311 • 559-638-3746 • Posted April 21, 2022 • Display Specs Page • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad • View Larger Images
thumbnail_image_1727560_1_1648251475.jpeg?1709 thumbnail_image_1727560_2_1648251476.jpeg?3043 thumbnail_image_1727560_3_1648251478.jpeg?7998 thumbnail_image_1727560_4_1648251479.jpeg?9416 thumbnail_image_1727560_5_1648251481.jpeg?1628
LONG EZ LONG-EZ RUTAN RV8 RV4 • $45,000 • FOR SALE • Long EZ IFR and Night Equipped 160KTAS on 7gph (7+ hr range) Acft 1100TT, Lyc O-235F1 (500SMOH) Ni Plated cyls. Lycon Pistons, New Baffling, LSE Ign, SS Exh, Ram int K&N Air filter, Sabre 6in Prop ext, rotating assy balanced to w/in 0.5gram. All Comps 72 cold. Travel Pods, Silver Bullet cruise Prop, GRT EFIS (no cost updates), HD Brakes, New B&C Alt, Starter, New Interior sheepskin seat covers, USB outlet on panel, Not ADS-B (choose which way to go with this 978 or 1090?). Seller can assist w install. All Safety and Speed mods done. Wing Bolts, rudder cables and canard bolts replaced 2021 • Contact Dave Meyer , Owner - located Granbury, TX 76049 United States Telephone: 6306606258 • Posted April 20, 2022 • Display Specs Page • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad • View Larger Images
thumbnail_image_1722780_1_1646406005.jpeg?9489 thumbnail_image_1722780_2_1646406006.jpeg?3819 thumbnail_image_1722780_3_1646406007.jpeg?326 thumbnail_image_1722780_4_1646406007.jpeg?9273 thumbnail_image_1722780_5_1646406008.jpeg?3238
A quickie, with no pics:
Quote
QUICKIE Q2 • $7,500 • ACCEPTING OFFERS • I have a Quickie Q2 for sale, too many projects right now, this one is quite advanced in the construction with really good details, its located en Zellwood Florida! the details of the terminations are excellent • Contact Edwin Medina , Owner - located Orlando, FL 32862 United States Telephone: 7875257768
Some more postings from the last day or so:
Quote
RUTAN LONG EZ AIRCRAFT • $37,500 • AVAILABLE FOR IMMEDIATE SALE • 2001 Rutan Longez,274 TTAF,mid time 0-235 Lycoming,ADS-B in/out,flies nice,extras,no texting • Contact Don Black , Owner - located Carlsbad, CA 92008 United States Telephone: 858_224_3069 • Posted April 24
VELOCITY SEFG • $48,500 • ACCEPTING OFFERS • Partially Completed project. PDF & Images upon request. 48500 vested,,negotiable • Contact John McGill , Owner - located Lake Havasu City, AZ 86403 United States Telephone: 928 846 5651
6 hours ago, bmckinney10 said:
The prices have gone up for all planes.  I was offered a similar value several times at Oshkosh last year for my Varieze.  Compare a Cessna 150/152 price from two years ago to today.  Getting close to double the price.
Getting price or asking price?  Regardless, thanks to massive deficit spending and .gov bailouts, inflation will gut-check the economy. I'm waiting for the pendulum to swing back before I buy, as the value is just not there for me.  12-18 months should do it...
https://www.forbes.com/sites/billconerly/2021/11/02/no-recession-in-2022-but-watch-out-in-2023/?sh=54347b5d3555
Today's Barnstormers
Quote
LONG EZE LONGEZ RUTAN • $42,500 • FOR SALE BY OWNER • 2018 Long eze ,110 total time , LYC 0290 ,Cato 3-blade Trio autopilot ,ADS -B ,electronic noise gear ,one electronic mag,one reg mag,carbon fiber wheel pans ,Armpit cooling (cylinder heads temp 325) ,I-pad set up ,current condition inspection,COME FLY IT AWAY ! • Contact Saeid Hamidi , Owner - located Yorba Linda, CA 92886 United States Telephone: 714-924-0802 • Posted May 1, 2022
Quote
VARI-EZE • $12,500 • OR BEST OFFER! • 0-200 engine with new cylinders,radios ,autopilot.needs nosegear and minor repair • Contact Joel Dozhier - ALPINE HELICOPTER SER. , - located Woodbridge, CA 95242 United States Telephone: 209-993-6077 • 209-368-8530 • Fax: 209-333-7345 • Posted April 29, 2022 • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad • View Larger Images
thumbnail_image_1719809_1_1651255194.jpeg?8612 thumbnail_image_1719809_2_1651255196.jpeg?4262
It is sad to see EZ's that have been neglected, just rotting away.  They are fantastic flying machines.  I was lucky to find two that had been "put away" for 16-20 years, but were at least stored indoors in decent climates.  I brought the VariEze back to life after 16 years of non-use in late 2020 and have close to 100 hours on it.  The Cozy 3 will be back in the air by this fall after an engine rebuild.  The Long-Ez was flying when I bought it, but is going through a full refurbishment with a repaint job.  There are likely 100's (if not more) of EZ's sitting in hangars or garages all across the country, just waiting for someone to get them flying again.
4 hours ago, zolotiyeruki said:
E-Racer project on B-stormers first listed at $15K, then $7.8K, reduced to $7.3K today.    Probably would have sold it if wasn't such a rare build.  The professionally-build cowls, canard, strakes, winglets and wings look nice.  They are probably worth that to a Long-ez builder.  Retracts, canopy, plans could be sold, I expect
History:
https://www.canardzone.com/forums/topic/21972-sales-ive-seen/?do=findComment&comment=82873
This one popped up today.  Also some discussion about its engine on Facebook:
Quote
LONG EZE LONGEZ RUTAN • $42,500 • FOR SALE BY OWNER • 2018 Long eze ,110 total time , LYC 0290 ,Cato 3-blade Trio autopilot ,ADS -B ,electronic noise gear ,one electronic mag,one reg mag,carbon fiber wheel pans ,Armpit cooling (cylinder heads temp 325) ,I-pad set up ,current condition inspection,COME FLY IT AWAY ! • Contact Saeid Hamidi , Owner - located Yorba Linda, CA 92886 United States Telephone: 714-924-0802 • Posted May 1, 2022 • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad • View Larger Images
thumbnail_image_1735934_1_1651431713.jpeg?2205 thumbnail_image_1735934_2_1651431714.jpeg?742 thumbnail_image_1735934_3_1651431715.jpeg?9535 thumbnail_image_1735934_4_1651503901.jpeg?2110 thumbnail_image_1735934_5_1651503902.jpeg?2856
B-stormers:   This looks very repairable but it is hard to value a damaged airplane.  No seller price, either.   The crash was discussed in the Cozybuilder's forum a year or two ago.   I would "insult" the seller with a low bid and go from there.  🙂  More pics in the ad
Quote
DAMAGED COZY IV • FOR SALE • 2004 Cozy IV; Straight-valve IO-360, Bendix fuel injection, dual electronic ignitions, 320 total hrs., 10 hrs. since prior complete teardown and reassembled to factory specs by Tim’s Aircraft Engines. Full panel with AvMap, GPS, ADS-B, autopilot with altitude hold, Terra NavComs, dual redundant electrical systems, leather interior. A hard landing resulted in significant damage that is reparable. I'll entertain best offer for aircraft with/without engine. This is a beautiful Cozy that has always drawn attention at fly-ins. • Contact Don Herzstein , Owner - located Long Beach, CA 90807 United States Telephone: (562) 706-5899 • Posted May 4, 2022
