kshort Posted January 15, 2010 Share Posted January 15, 2010 Hi Folks: Please point me in the best direction for a (reasonable cost) vendor for seat belts and shoulder harness' for my Cozy MK IV. I am familiar with Hooker Harness and the Van's Aircraft Accessory catalog... Any others??? Thanks I'm gettin' closer! :0) kds Quote Link to comment Share on other sites More sharing options...
vjdslk Posted January 15, 2010 Share Posted January 15, 2010 I used Andover restraints. Reasonably priced and will do custom work. http://www.andoauto.com/seat_belts.htm Jon Dembs Cozy MKIV Rocklin, CA Quote Link to comment Share on other sites More sharing options...
rviglierchio Posted January 15, 2010 Share Posted January 15, 2010 The RV guys rave about these folks: http://www.crowenterprizes.com/ I didn't hear from them until after buying Hooker. Hookers are quite nice but they say Crow is much more economical. Jon, was up in Lincoln twice in the last few days getting an L-39 into the paint shop. Sure would like to see your plane sometime........? Quote Link to comment Share on other sites More sharing options...
rickh Posted January 16, 2010 Share Posted January 16, 2010 http://mrproducts.com/ I have not dealt with them directly, but they are a product one of my suppliers carries. Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
Kent Ashton Posted January 16, 2010 Share Posted January 16, 2010 For a Cozy, I would avoid the kind of belt below with separate latch and adjusters on each side. The belts in a Cozy are so short that there's not much space between the latch, adjuster, and belt mount which makes it awkward to pull down the straps to adjust them. They'll work, just not ideal, IMHO. I had them on my Cozy and went back to simple ACS belts with the square silver latch that you pull up to release which has the belt adjustment part integrated with the latch. Pax also find them easier to adjust. I like the idea of a crotch restraint, though. If you can find the simple belts with a crotch restraint, that'd be ideal (if you also have a hardpoint for the end of the crotch restraint.) Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Kinnerhatz Posted January 16, 2010 Share Posted January 16, 2010 Lap belts with adjusters between the buckle and the airframe mount can work, but ideally the adjuster should be flipped around from normal practice so that you pull up on the strap to tighten rather than pulling down. Kent is right, pulling down on the loose end to tighten is very hard in our cramped cockpits. Most any custom harness maker can flip the adjuster around if asked. Quote Link to comment Share on other sites More sharing options...
Lynn Erickson Posted January 17, 2010 Share Posted January 17, 2010 Hi Folks: Please point me in the best direction for a (reasonable cost) vendor for seat belts and shoulder harness' for my Cozy MK IV. I am familiar with Hooker Harness and the Van's Aircraft Accessory catalog... Any others??? Thanks I'm gettin' closer! :0) kds the best belts for the cozy are the ones sold by ACS. http://www.aircraftspruce.com/catalog/appages/seatbelt5.php They are designed to work in our cockpits the lap belt adjustments are at the buckles and pull out from the center. this is best because there is little room to have a buckle and a separate adjuster. if the adjuster is on the side it gets caught in the cushion and is very hard to readjust. the shoulder straps tighten by pulling down and have a release strap that is pulled up to release. reasonable price and they work perfect for our planes, and no need to re invent the seat belt Quote Evolultion Eze RG -a two place side by side-200 Knots on 200 HP. A&P / pilot for over 30 years Link to comment Share on other sites More sharing options...
Jack Morrison Posted January 17, 2010 Share Posted January 17, 2010 Another place to look is Aircraft Belts Inc. top quality and large color variety. Jack Quote Link to comment Share on other sites More sharing options...
Kinnerhatz Posted January 18, 2010 Share Posted January 18, 2010 The aluminum end fittings on the Aircraft Spruce belts shown in the above link bother me. I'd like to know if they were engineered and to what loads they have been designed. They may be fine, but who knows? Quote Link to comment Share on other sites More sharing options...
TMann Posted January 18, 2010 Share Posted January 18, 2010 Most aircraft designs are available in either aluminum or stainless. It's more likely that you would pull out the hardpoints before the hardware failed. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Kent Ashton Posted January 19, 2010 Share Posted January 19, 2010 The aluminum end fittings on the Aircraft Spruce belts shown in the above link bother me. I'd like to know if they were engineered and to what loads they have been designed. They may be fine, but who knows? They are pretty standard fittings. You will find them on lots of aircraft belts--even military. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Steve Innova Posted January 19, 2010 Share Posted January 19, 2010 I have a set of hooker harnesses, for sale, half off. Brand new, still in the box. Quote Link to comment Share on other sites More sharing options...
mfryer Posted January 19, 2010 Share Posted January 19, 2010 The aluminum end fittings on the Aircraft Spruce belts shown in the above link bother me. I'd like to know if they were engineered and to what loads they have been designed. They may be fine, but who knows? I have two of the ACS belts for my long-ez project and the fittings are definatly steel. Quote Link to comment Share on other sites More sharing options...
Kinnerhatz Posted January 19, 2010 Share Posted January 19, 2010 I use the ACS belts and the end fittings are aluminum, but they were purchased years ago. I did make one modification to them. I added a strap of seat belt webbing with loops stitched to each end. The strap goes between the two shoulder harness belts and holds them about 9-inches apart just behind the occupants neck. This compensates for the Long-EZ mounting points which are too far apart. Quote Link to comment Share on other sites More sharing options...
mfryer Posted January 19, 2010 Share Posted January 19, 2010 Interesting. The ACS site says they have aluminium fittings also, but mine are steel. I purchased mine about a year and a half ago. Quote Link to comment Share on other sites More sharing options...
