kshort Posted December 15, 2009 Share Posted December 15, 2009 Ok all you expert builders, I am looking for a plexiglas safe substance to assist me in removing the spraylat from the inside surface of my canopy. The spraylat on the inside surface is about 7+ years old. I can get it off now in very small amounts (1/2 inch sq size pieces) but would like do it quicker. Any help??? Thanks Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted December 15, 2009 Share Posted December 15, 2009 You can apply a couple more thick layers and let them dry 24 hours. They will bond to the lower layers (and soften them) and the thicker application will be easier to strip off. Or place wet towels over the canopy and keep them wet for a day or so, It will soak into the Spraylat which will wash off with a hose. You close to flying, Kevin? Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
CBarber Posted December 17, 2009 Share Posted December 17, 2009 Be careful. I had more trouble than described and I have a couple of pretty substantial scratches as a result. I have since learned that you are not suppossed to leave the spraylot on for extended periods of time. Over a year, IIRC. Also, exposure to sunlight will make it much harder to remove. Mine suffered from both time and some sun. I added new spraylot over the old as well as soaked it. Goofoff (sp?) helped but it was still very tedious for me. All the best, Christopher Barber Houston, GSOT Quote Christopher Barber Velocity SE/FG w/yoke. Zoom, zoom, zoom. www.LoneStarVelocity.com Live with Passion... Link to comment Share on other sites More sharing options...
