cozybldr Posted November 11, 2009 Share Posted November 11, 2009 I remember seeing in either the Canard Pusher or the Cozy newsletter about somebody who built a forced air breathing system. I believe they used a respirator mask with one of the cartridges removed, vacuum hose, cooking pan, and a squirrel cage fan. I seem to remember duct tape in there as well. Does anybody remember which issue had that series of pictures? I want to construct one for myself. Yeah, I could plop down $600 for one already made, but this is homebuilt aviation. We ought to be able to do it for a whole lot less. Quote To dream and those who dare will always lead the way. Link to comment Share on other sites More sharing options...
TMann Posted November 11, 2009 Share Posted November 11, 2009 The only type of 'fresh air' mask that I am familiar with runs off of a compressor that you place outside of the shop and it is usually associated with painting. If this is what you are looking for, it's a very expensive corner to cut. Some of these paints will kill you before you can get to the door. If your intended use is for another application ........... never mind. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
schmeddz Posted November 11, 2009 Share Posted November 11, 2009 I saw an article in Kitplanes about 10-13 years ago. Central States newsletter had one article also. The guy used a bathroom vent fan and all the hoses and duct tape used were from home supply stores. He built the whole thing for under 50 bucks. I just replaced my old mask on my machine with a respirator from AO Safety for 20 bucks. A garden hose with quick disconnects that won't collapse as your moving around the project works well. I think food grade clear hose from the hardware store works well. Quote Link to comment Share on other sites More sharing options...
schmeddz Posted November 11, 2009 Share Posted November 11, 2009 Here's a link to a similar article. http://www.sonerai.net/CMS/index.php?option=com_content&task=view&id=56&Itemid=1 A pool hose can also be found at the hardware/lumber stores. Mines a commercial HVLP system. The pool hose would work better for the bathroom fan to move a larger mass of air. I use fresh air for sanding and all other things where there's lots of dust and nasty stuff in the air. Quote Link to comment Share on other sites More sharing options...
cozybldr Posted November 11, 2009 Author Share Posted November 11, 2009 That's the one! Do you remember which issue that was in, please? Thanks, Rick Quote To dream and those who dare will always lead the way. Link to comment Share on other sites More sharing options...
cozybldr Posted November 11, 2009 Author Share Posted November 11, 2009 That was the system I was thinking about. Very effective as I remember in that the guy tested it using acetone fumes at 3 inches to see if he could smell them. He couldn't and I believe he did it because of the epoxy fumes. Thanks! Rick Here's a link to a similar article. http://www.sonerai.net/CMS/index.php?option=com_content&task=view&id=56&Itemid=1 A pool hose can also be found at the hardware/lumber stores. I use fresh air for sanding and all other things where there's lots of dust and stuff. Quote To dream and those who dare will always lead the way. Link to comment Share on other sites More sharing options...
schmeddz Posted November 11, 2009 Share Posted November 11, 2009 I developed the allergy to the epoxy's and I use mine a lot. I wished I had used it more when I was building a lot. I may pay a price later in life! I also use a hood and sometimes wear a full tyvek suit when actually painting. You can't be too careful. Quote Link to comment Share on other sites More sharing options...
