aviator_edb Posted October 29, 2009 Share Posted October 29, 2009 What is the best way to prep a flox or micro outside corner. I had to really work at it to get all the foam off of the cured glass on the seatback. What are others doing on this? Quote Link to comment Share on other sites More sharing options...
Phil Kriley Posted October 29, 2009 Share Posted October 29, 2009 Why did you remove all of the foam on your seatback? Quote Phil Kriley Cozy #1460 Chapter 13 - nose Right wing done - working on right winglet. Link to comment Share on other sites More sharing options...
steve Posted October 29, 2009 Share Posted October 29, 2009 What is the best way to prep a flox or micro outside corner. I had to really work at it to get all the foam off of the cured glass on the seatback. What are others doing on this? i use a large long neck dermal like tool with a tear drop shape course bit.i go fast untill i hit white micro then i slow way down and cut away at it a little bit at a time. i have other air tools that work, but this is the best for me. tool town and its 150.00 Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
aviator_edb Posted October 29, 2009 Author Share Posted October 29, 2009 Why did you remove all of the foam on your seatback? Just talking about the 1/4" or so for the flox corner. Quote Link to comment Share on other sites More sharing options...
Phil Kriley Posted October 29, 2009 Share Posted October 29, 2009 Just talking about the 1/4" or so for the flox corner. Oh! OK - then I agree with the previous responder - I used a cone-shaped Dremel bit. You just have to be careful not to cut all the way through the glass. Quote Phil Kriley Cozy #1460 Chapter 13 - nose Right wing done - working on right winglet. Link to comment Share on other sites More sharing options...
Neverquit Posted October 29, 2009 Share Posted October 29, 2009 Yep, cone shaped bit does best. If you don't have a Dremel, sand or cut a 45 deg. bevel to a piece of scrap wood. I use a paint stirring stick. Get some sticky backed 36 grit and wrap it arount the wood. Works great. Quote Link to comment Share on other sites More sharing options...
TMann Posted October 29, 2009 Share Posted October 29, 2009 I just trimmed out the triangular piece with an exacto knife (the large type) then trimmed off any excess that remained on the backside of the glass I was bonding to. Finish it up with a little sanding (I used a Fein for that) and you're good to go. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Edge 513 Posted October 29, 2009 Share Posted October 29, 2009 I'm confused, but thats nothing new. What foam were you taking OFF of the seatback? Maybe OUT of but not OFF of? Why are you removing foam off of something there? Also, the flox fillets are used when you are stripping the seatback [and bulkheads] to the fuse sides with the 2" BID tapes. Quote Self confessed Wingnut. Now think about it...wouldn't you rather LIVE your life, rather than watch someone else's, on Reality T.V.? Get up off that couch!!! =) Progress; Fuselage on all three, with outside and inside nearly complete. 8 inch extended nose. FHC done. Canard finished. ERacer wings done with blended winglets. IO540 starting rebuild. Mounting Spar. Starting strake ribs. Link to comment Share on other sites More sharing options...
steve Posted October 29, 2009 Share Posted October 29, 2009 I'm confused, but thats nothing new. What foam were you taking OFF of the seat-back? Maybe OUT of but not OFF of? Why are you removing foam off of something there? Also, the flox fillets are used when you are stripping the seat back [and bulkheads] to the fuse sides with the 2" BID tapes. any where you need the glass to bond to glass and you cant or don't have a 1" over lap to work with. and the seat back had such a joint at the bottom(?)and you(we) carved out the foam and replaced it with flox (but you know that:p ). Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
Edge 513 Posted October 30, 2009 Share Posted October 30, 2009 So thats what was referred to. Check. Flox not micro. Quote Self confessed Wingnut. Now think about it...wouldn't you rather LIVE your life, rather than watch someone else's, on Reality T.V.? Get up off that couch!!! =) Progress; Fuselage on all three, with outside and inside nearly complete. 8 inch extended nose. FHC done. Canard finished. ERacer wings done with blended winglets. IO540 starting rebuild. Mounting Spar. Starting strake ribs. Link to comment Share on other sites More sharing options...
