Looks like what is listed in the Larry Fitzgerald Composites website as a Cozy. Doesn't look much like one really, does anybody know if any of these have actually flown?
http://www.fitzair.net/
http://cgi.ebay.com/ebaymotors/Cozy-III-Classic-Experimental-Canard-Aircraft-Kit_W0QQitemZ300360883379QQcmdZViewItemQQptZMotors_Aircraft?hash=item45eee75cb3#v4-35
The attachments for the MLG look completely alien. I don't know what the thing next to the fus is, looks too long for a canard. Maybe its a mast...
US2500 - no bids.
Mark Spedding - Spodman
Darraweit Guim - Australia
Cozy IV #1331 -  Chapter 09
www.mykitlog.com/Spodman
The landing gear is standard Cozy III--based on Long-EZ gear. However, I would not buy anything from Larry Fitzgerald, to wit:
[From Cozy Archives]
"Date: Nov 17, 2006 11:52 AM
Subject: COZY: Message from Nat Puffer
Builders - Nat Asked me to pass this message from him on to you.
Dear Builders,
Yesterday we received a call from Aircraft Spruce, that someone called
who needed advice on canard lift tabs, and they asked me if I would be
willing to advise. Certainly, I said, so a little bit later, I got a call
from a Mr. Chuck Ebert, of the FAA. He said he was asked to supply advice to
a builder who was having a problem with his lift tabs corroding, because of
the urethane pour foam used to fill the canard. He volunteered that the
canard had been made by Fitzgerald Composites. I nearly went into orbit!
Back in 1991, a builder had Larry Fitzgerald make a canard for his Cozy
III. When he showed it to another builder, that builder said it seemed to be
too heavy. It was 45 lbs, compared to the normal weight of 29 lbs. So I
called the builder and advised him that there must be something wrong with
the canard, because it was far too heavy. The builder said he decided not to
use it, and offered to cut it into sections to see what was inside. When I
got the sample section, I almost choked. It appeared that it had been laid
up inside a mold, skin first, and then pieces of plastifoam placed against
the skin, and then the large void on the inside filled with urethane pour
foam. Also, the mold did not have the correct contour, so there was about a
1/4 inch layer of micro on the outside to correct the contour. There was a
dipole antenna installed in the leading edge, with the co-ax right alongside
of one of the dipoles, so I was sure it would not work. I showed the sample
to Burt Rutan, and Ben Owen at the EAA, and they almost choked. I showed
this sample in my forum at Oshkosh, and published a picture of it in
newsletter #35 along with an alert to all builders that Fitzgerald
Composites was not an authorized supplier, and his parts were judged to be
unairworthy. This resulted in several other builders relating similar bad
experiences with Fitzgerald composites. Apparently Larry Fitzgerald is still
out there making parts for people.
My recommendation would be that if anyone is using or planning to use
any Fitzgerald Composite parts, to ground the airplane until those parts are
replaced with parts made per plans, and if anyone wants a reference to
someone making parts per plans, to please call me.
Best regards,
Nat"
