jpolenek Posted February 3, 2009 Share Posted February 3, 2009 If anyone is real curious .......... send me a check and I'll ship my canard to you. Why not take it to Rough River and do a demo by loading it to failure? Given the general lack of test data available for these designs, there would probably be quite a bit of interest in the results. (Put a tent around it and you could charge admission for the peep show. ) Joe Polenek Quote Joe Cozy Mk IV #1550 Link to comment Share on other sites More sharing options...
TMann Posted February 3, 2009 Author Share Posted February 3, 2009 Should I bring my own sand? Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Jack Morrison Posted February 3, 2009 Share Posted February 3, 2009 Funny about weighing product going on a project. When I painted my E Racer, I weighed all the product to paint the AC, less packaging and can weight came to 97 lbs. Weighed the AC before painting, all preped for paint and weighed after completed. Painted AC weighed +23 lbs. Go figure. Jack Quote Link to comment Share on other sites More sharing options...
brainfart Posted February 3, 2009 Share Posted February 3, 2009 > weight came to 97 lbs. Weighed the AC before painting, all preped for paint > and weighed after completed. Painted AC weighed +23 lbs. Overspray and volatile solvents. Quote Link to comment Share on other sites More sharing options...
Steve Innova Posted February 3, 2009 Share Posted February 3, 2009 If anyone is real curious .......... send me a check and I'll ship my canard to you. Figure on 30+# for frieght. Figure on on 170 lbs once you build a crate and packing... I just did this. The canard was 25lbs, box 150 lbs. Quote Link to comment Share on other sites More sharing options...
TMann Posted February 3, 2009 Author Share Posted February 3, 2009 What is more likely is that I would cut the canard straight through one of the lift tabs from front to back and display it at our EAA Chapter hangar. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
rickh Posted February 12, 2009 Share Posted February 12, 2009 As you know from my Chapter 25 pages, the "milling machine" was the cat's meow for contouring the top of the canard. I was unable to do that on the bottom because the hinges get in the way. I made a sled to contour sand the bottom of the canard. I'm not sure if the WH Contour Sled idea is better than folding napkins or crushed ice, but it's up there. I'll have pix up on my website shortly. Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
Wayne Hicks Posted February 12, 2009 Share Posted February 12, 2009 About the weight of your first canard... Did you squeegee out the excess epoxy from each spar cap tape as you went along or did you rely on the vac-bagging to draw out the excess for you? As for what to do with the first canard, a proof load test is mucho cooler than a cutaway specimen. Quote Wayne Hicks Cozy IV Plans #678 http://www.ez.org/pages/waynehicks Link to comment Share on other sites More sharing options...
TMann Posted February 12, 2009 Author Share Posted February 12, 2009 I squeegeed as I went. I also used heat to thin it out as much as possible. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
mfryer Posted February 13, 2009 Share Posted February 13, 2009 About the weight of your first canard... Did you squeegee out the excess epoxy from each spar cap tape as you went along or did you rely on the vac-bagging to draw out the excess for you? As for what to do with the first canard, a proof load test is mucho cooler than a cutaway specimen. He could do both. There still might be some relatively undamaged areas left that could be made into a cutaway. Quote Link to comment Share on other sites More sharing options...
TMann Posted March 1, 2009 Author Share Posted March 1, 2009 Just realized I never posted an exact weight as a result of my rebuild. 19 lb 1 oz Well worth the effort I think. I'll transfer that experience to the new parts I build. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Cozy1200 Posted March 2, 2009 Share Posted March 2, 2009 Wow. I'd still like to know where that extra 10lbs is? I'd like to lose 10lbs either off me or my plane! Quote Drew Chaplin (aka the Foam Whisperer) --- www.Cozy1200.com - I'm a builder now! --- Brace for impact... Link to comment Share on other sites More sharing options...
TMann Posted March 2, 2009 Author Share Posted March 2, 2009 Wow. I'd still like to know where that extra 10lbs is?Yeah, me too but I through quessing. I think it's in the spar cap. .........moving on. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
