TMann Posted December 15, 2008 Author Share Posted December 15, 2008 The top profile has been checked against the templates and sanded to match. I applied my hardshell coat and when that has cured, I'll sand it out and skin it. ......toast soon. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
TMann Posted December 17, 2008 Author Share Posted December 17, 2008 What I would do different ........... JD at Infinity suggested cutting the canard cores as two pieces vs four and then run the spar cap and shear web the full length. That was a good call. That combined with the extruded aluminum supports the full length of the canard ......... very straight. I also installed my hardpoints before I installed the bottom skin. In hindsight I think I would have cut the cores and make the most inboard and outboard (for each side) hardpoints the full shape of the canard profile. This would provide a good guide to sand to for the rest of the profile. ......just some thinking. I really wish this was my second EZ. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Steve Innova Posted December 19, 2008 Share Posted December 19, 2008 What I would do different ........... JD at Infinity suggested cutting the canard cores as two pieces vs four and then run the spar cap and shear web the full length. That was a good call. That combined with the extruded aluminum supports the full length of the canard ......... very straight. Correct me if I'm wrong, but if the bottom spar-cap runs full length, where will the elevator counterweights go? Me thinks you're going to have to cut two 1" wide slots into that bottom spar cap at the ends. Quote Link to comment Share on other sites More sharing options...
TMann Posted December 19, 2008 Author Share Posted December 19, 2008 Correct me if I'm wrong, but if the bottom spar-cap runs full length, where will the elevator counterweights go? Me thinks you're going to have to cut two 1" wide slots into that bottom spar cap at the ends. That is correct. It's pretty easy to cut the slots with a router. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
steve Posted December 20, 2008 Share Posted December 20, 2008 Correct me if I'm wrong, but if the bottom spar-cap runs full length, where will the elevator counterweights go? Me thinks you're going to have to cut two 1" wide slots into that bottom spar cap at the ends. ok, your not right. the cut out is 2 or 3 inches and is cut from the te. the spar tape is 3" and is in the center so you dont need to cut it.if you need to cut the spar tape you mite have a issue with the rudder falling off:p Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
TMann Posted December 20, 2008 Author Share Posted December 20, 2008 ok, your not right. the cut out is 2 or 3 inches and is cut from the te. the spar tape is 3" and is in the center so you dont need to cut it. if you need to cut the spar tape you mite have a issue with the rudder falling off:p We'll know soon. It would be nice if it's not an issue but I went into this figuring it would have to be addressed. I'll post when I get to that. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
TMann Posted December 21, 2008 Author Share Posted December 21, 2008 Done ......... finally. Top skin is on ........ it's in the vacuum bag and tucked in under a pair of electric blankets for the night. I need to get my plotter back out and reconnected so I can print my templates for the nose. working .... working .... bit by bit. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
