Spodman Posted March 28, 2008 Share Posted March 28, 2008 Spotlight at Essendon DFO have these on a runout special, $75, 5 left, (after I got mine). This compares OK with my experience of US prices and save your freight. SWMBO won't let me try it out until my birthday... Appears identical to US example I've seen Drew Chaplin use, but with Oz power supply. They also have a cheaper alternative, but the blades look like plain steel and they are PINK! Quote Mark Spedding - SpodmanDarraweit Guim - AustraliaCozy IV #1331 - Chapter 09www.mykitlog.com/Spodmanwww.sites.google.com/site/thespodplane/the-spodplane Link to comment Share on other sites More sharing options...
Cozy1200 Posted March 28, 2008 Share Posted March 28, 2008 Spotlight at Essendon DFO have these on a runout special, $75, 5 left, (after I got mine). This compares OK with my experience of US prices and save your freight. SWMBO won't let me try it out until my birthday... Appears identical to US example I've seen Drew Chaplin use, but with Oz power supply. They also have a cheaper alternative, but the blades look like plain steel and they are PINK! I'd say that's an excellent price. I paid $80 USD from Jamestowndistributors.com and then had to have it shipped over. I couldn't find them locally at that time. I've seen them slightly cheaper in the states, but they were out of stock Congrats. HENNIE You should order these NOW!!!! Quote Drew Chaplin (aka the Foam Whisperer) --- www.Cozy1200.com - I'm a builder now! --- Brace for impact... Link to comment Share on other sites More sharing options...
Lifessamsara Posted March 28, 2008 Share Posted March 28, 2008 Spodman that is a great score! Do any of you know if they will effectively cut kelvar as well? I hear it is a bugger to cut. I will shoot off after work to pick up a pair if they can cut kevlar. Cheers, Bruce. Quote Link to comment Share on other sites More sharing options...
Hennie Engelbrecht Posted March 28, 2008 Share Posted March 28, 2008 Spotlight at Essendon DFO have these on a runout special, $75, 5 left, (after I got mine). This compares OK with my experience of US prices and save your freight. SWMBO won't let me try it out until my birthday... Appears identical to US example I've seen Drew Chaplin use, but with Oz power supply. They also have a cheaper alternative, but the blades look like plain steel and they are PINK! It's not yellow.. is it ad DRitz Quote Link to comment Share on other sites More sharing options...
Cozy1200 Posted March 28, 2008 Share Posted March 28, 2008 It's not yellow.. is it ad DRitz It's more difficult to find the scissors with the Dritz Name on them. In my search, I discovered that their branded by several different names. Dritz, Consew, EC. They are all the same product. Quote Drew Chaplin (aka the Foam Whisperer) --- www.Cozy1200.com - I'm a builder now! --- Brace for impact... Link to comment Share on other sites More sharing options...
Hennie Engelbrecht Posted March 29, 2008 Share Posted March 29, 2008 It's more difficult to find the scissors with the Dritz Name on them. In my search, I discovered that their branded by several different names. Dritz, Consew, EC. They are all the same product. I went to the local Spotlight shop and looked at the EC. The blade seem very flimsey. Here the price is $150 Aus... hennie Quote Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted March 29, 2008 Share Posted March 29, 2008 If you do not drop them you could probably ge through the whole plane with probably 3 Dritz blade sets, we are talking about the genuine article with carbon inserts not other brands of scissors like B&D. Eventually epoxy will build up on them and performance will fall off (first sign is it won't cut peel ply without snagging) you need to look at them under a magnifier and shave the epoxy off with a razor blade. Good as new again. The blades may be small but they will cut through three layers of wet BID and munch through up to six with a little more patience. Regards, Chrissi Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
Hennie Engelbrecht Posted March 29, 2008 Share Posted March 29, 2008 If you do not drop them you could probably ge through the whole plane with probably 3 Dritz blade sets, we are talking about the genuine article with carbon inserts not other brands of scissors like B&D. Regards, Chrissi The EC definitely does not have the insert. It has a formed blade. Are we sure that EC is the same as Dritz??? Hennie Quote Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted March 29, 2008 Share Posted March 29, 2008 Hennie, You are going to have to look VERY closely as the insert is about half a dime sized, its flush in there and not immediately evident. ...C&R Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
Hennie Engelbrecht Posted March 29, 2008 Share Posted March 29, 2008 Hennie, You are going to have to look VERY closely as the insert is about half a dime sized, its flush in there and not immediately evident. ...C&R Ok, I was looking for a blade bolted on. I see the insetr on a photograph on Wicks site. Thanks Hennie Quote Link to comment Share on other sites More sharing options...
Spodman Posted March 31, 2008 Author Share Posted March 31, 2008 Mine have the insert, on both heads. I expect both with be useful, the foot thingie comes off. I'm not intending to use them for cutting the fibreglass cloth, my experiments with a disc cutter seem more efficient. I got them for scissor trim of fresh layups, Drew has sold me on that technique. Got it from the Grrrrls I think? Marked price on mine was $150 also, but they are, like, 'marked down'! Maybe you can challenge your Spotlight to match the price. Not surprised they aren't leaping out the door at the standard price. Quote Mark Spedding - SpodmanDarraweit Guim - AustraliaCozy IV #1331 - Chapter 09www.mykitlog.com/Spodmanwww.sites.google.com/site/thespodplane/the-spodplane Link to comment Share on other sites More sharing options...
Cozy1200 Posted March 31, 2008 Share Posted March 31, 2008 I'm not intending to use them for cutting the fibreglass cloth, my experiments with a disc cutter seem more efficient. I've used the disc cutter and still prefer dritz. But to each his own. Got it from the Grrrrls I think? All good things come from the Girrrls!! I'm not sure from whom they got the idea. Quote Drew Chaplin (aka the Foam Whisperer) --- www.Cozy1200.com - I'm a builder now! --- Brace for impact... Link to comment Share on other sites More sharing options...
Lifessamsara Posted March 31, 2008 Share Posted March 31, 2008 I'm the proud owner of an EC Cutter (with the attachments) as well! Spod, I went for the carbon pattern instead of the Red/brown as displayed in your pic'. Drew, I will have to make time one weekend to drop by and check out your Cozy fabrication facility. Cheers, Bruce. Quote Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted March 31, 2008 Share Posted March 31, 2008 We have to give credit to Jerry Schneider for the Dritz scissors. Thanks Skippy! Regards, Chrissi Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
Cozy1200 Posted March 31, 2008 Share Posted March 31, 2008 Drew, I will have to make time one weekend to drop by and check out your Cozy fabrication facility. Let's have a plane day! I'll warn you, lurkers turn into plane slaves in my shop! Quote Drew Chaplin (aka the Foam Whisperer) --- www.Cozy1200.com - I'm a builder now! --- Brace for impact... Link to comment Share on other sites More sharing options...
Jerry Schneider Posted March 31, 2008 Share Posted March 31, 2008 We have to give credit to Jerry Schneider for the Dritz scissors. Thanks Skippy! One small step for Canards. One giant leap for Canard Builders. EVEN A BLIND SQUIRREL SOMETIMES FINDS A NUT! Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
Spodman Posted April 1, 2008 Author Share Posted April 1, 2008 Well done Bruce, well done Jerry, well done squirrel:cool: Quote Mark Spedding - SpodmanDarraweit Guim - AustraliaCozy IV #1331 - Chapter 09www.mykitlog.com/Spodmanwww.sites.google.com/site/thespodplane/the-spodplane Link to comment Share on other sites More sharing options...
Spodman Posted April 17, 2008 Author Share Posted April 17, 2008 Was in there yesterday buying something for me Mum. 4 left. Quote Mark Spedding - SpodmanDarraweit Guim - AustraliaCozy IV #1331 - Chapter 09www.mykitlog.com/Spodmanwww.sites.google.com/site/thespodplane/the-spodplane Link to comment Share on other sites More sharing options...
Hennie Engelbrecht Posted August 16, 2008 Share Posted August 16, 2008 Hi all Have a look at this tool I spotted in a local hardware shop. It is called a Bosch universal cordless cutter. It has a carbide insert http://www.bosch-do-it.com.au/boptocs2-au/Product.jsp;jsessionid=FDD350F70990E79B6C4625C3FEDEDE83.worker1?country=AU&lang=en&division=hw&ccat_id=100770&event=getDetails&object_id=14253 or:http://www.bosch-pt.com/productspecials/green/xeo/uk/en/ Not sure how the rotating part will stand up to epoxy ingress Hennie Quote Link to comment Share on other sites More sharing options...
TMann Posted August 16, 2008 Share Posted August 16, 2008 I have the corded version and have to say I like the Dritz and Pizza Wheel style cutter better. Yeah, I wouldn't use the Bosch cutter on wet epoxy. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
EZ AHAB Posted August 16, 2008 Share Posted August 16, 2008 Just bought a set at Wicks on my way home from Osh at the advice of the Girrrls. Also got most of the other stuff from the CG toolkit that I didn't already have like the permagrit rotary bits. I've only tried the scissors on dry BID so far but they cut it like butter. Erick at Wicks said they use theirs for cutting all sorts of stuff including Kevlar. Now I just have to get back to work on MY airplane! Quote EUREKA CNC Extreme Precision CNC Hotwire Cutting http://www.eurekacnc.com Perfection To The Core! Link to comment Share on other sites More sharing options...
Jon Matcho Posted August 17, 2008 Share Posted August 17, 2008 It is called a Bosch universal cordless cutter. ... Not sure how the rotating part will stand up to epoxy ingress I wouldn't want to be near that blade spinning at 240 RPM as it began cutting into laid-up glass. I can't imagine how it would be good on dry glass either. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
TMann Posted August 17, 2008 Share Posted August 17, 2008 I can't imagine how it would be good on dry glass either.They don't do too bad on dry fabric. I still prefer the Dritz. I'm not a big fan of the cordless stuff. It seems they always run out at the wrong time. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
EZ AHAB Posted August 17, 2008 Share Posted August 17, 2008 The cool thing about the Dritz cordless scissors is that if the battery dies, you just plug it in using the same wall transformer that charges the battery. This allows the same scissors to be used with a power cord so you don't have to wait to recharge. Quote EUREKA CNC Extreme Precision CNC Hotwire Cutting http://www.eurekacnc.com Perfection To The Core! Link to comment Share on other sites More sharing options...
Hennie Engelbrecht Posted September 11, 2008 Share Posted September 11, 2008 Have a look at this tool I spotted in a local hardware shop. It is called a Bosch universal cordless cutter. It has a carbide insert" My son bought me a Bosch cutter for my birthday and I must say I am impressed. It cuts through 6 layers of BID fibreglass with no problem. I will test it more over the weekend Hennie Quote Link to comment Share on other sites More sharing options...
