killerb1971 Posted February 2, 2008 Share Posted February 2, 2008 Well....It wasn't much of a start, but its still a start. I got as far as trimming the front seat back and cutting the glass for the first layup before I went to work. I realized I did not have any peel ply!!! Here I thought I was prepared. So I ordered some 1" and 2" from Spruce and it should be here Sat. This is where it all begins. The clock has officialy started!!!! I have 1.5hrs logged so far. Just 4998.5 hrs to go!! : ) Isn't this FUN! Quote Rob Wiehl COZY MKIV #1521 Link to comment Share on other sites More sharing options...
TMann Posted February 2, 2008 Share Posted February 2, 2008 Isn't this FUN!..... it certainly is! Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
macleodm3 Posted February 2, 2008 Share Posted February 2, 2008 It Really is FUN! Quote Andrew Anunson I work underground and I play in the sky... no problem Link to comment Share on other sites More sharing options...
killerb1971 Posted February 3, 2008 Author Share Posted February 3, 2008 I looked at chapter 2 pg 5 and it looks as if the IP is supposed to be cut up into 3 sections to fit F28 on the same foam. I didn't notice this untill I had the entire IP traced onto the 2 pieces of foam I glued together. Is it necessary to flip the foam over and re cut the M drawing and trace it that way, or can I just buy an extra piece of foam for F28? The IP just barely fits on the 2 pieces of foam, but it is all there. I have also heard about people needing to add 1/4" to the bottom of the IP to make it fit the fuselage, is this a necessary modification? I don't mind re doing anything, I just want it to be right. Quote Rob Wiehl COZY MKIV #1521 Link to comment Share on other sites More sharing options...
Kraig Posted February 3, 2008 Share Posted February 3, 2008 You can 5-minute epoxy as many pieces of foam together as you need to make a bulkhead. Don't bother redrawing, just add foam as needed to complete the bulkhead's. If you are not familiar with the popular duct tape hinge method of joining two pieces of foam together, check out Wayne hicks site to learn it. Very simple and will be used extensively throughout the build. Also, do add the 1/4" to the bottom of the IP, even if you have to add it with the method above. Also, make the width of the foam between the legholes 3.8" wide, not 3.5". This is from FAQ 4.22 on Marc's site. You should have all these FAQ's bookmarked and go over them well before, during and after each step is completed. Go to this site, www.ttcse.com/cozylinks/ for all your research needs. It is most valuable, probably one of my most used sorces of reference. Kraig Quote Link to comment Share on other sites More sharing options...
killerb1971 Posted February 3, 2008 Author Share Posted February 3, 2008 You can 5-minute epoxy as many pieces of foam together as you need to make a bulkhead. Don't bother redrawing, just add foam as needed to complete the bulkhead's. If you are not familiar with the popular duct tape hinge method of joining two pieces of foam together, check out Wayne hicks site to learn it. Very simple and will be used extensively throughout the build. Also, do add the 1/4" to the bottom of the IP, even if you have to add it with the method above. Also, make the width of the foam between the legholes 3.8" wide, not 3.5". This is from FAQ 4.22 on Marc's site. You should have all these FAQ's bookmarked and go over them well before, during and after each step is completed. Go to this site, www.ttcse.com/cozylinks/ for all your research needs. It is most valuable, probably one of my most used sorces of reference. Kraig Thanks Kraig! I appreciate the info. I'll make it a point to do more research before I get started from now on. I'll post more when I make more progress. Quote Rob Wiehl COZY MKIV #1521 Link to comment Share on other sites More sharing options...
rickh Posted February 4, 2008 Share Posted February 4, 2008 I looked at chapter 2 pg 5 and it looks as if the IP is supposed to be cut up into 3 sections... I think I cut mine into five pieces. Glue any number of pieces together, make it look like the [final] picture. If you fear you're gonna bust up the IP foam handling it before it gets glassed, just cut the major holes out. Cut the smaller ones once it's glassed. Do make the IP a bit longer on the bottom, sanding the excess off is trivial to adding additional foam once it's done. Mine came out about 1/4" short at the OS edges, flush in the center. Sand/trim the angles at the bottom corners slightly large too, you can trim them to fit when you assemble the sides... easy. Cut the seat back map and heater duct slots narrow and short, trim to size in Ch 6. The LG bulkheads (F-22 doubler, F-28, and IP too) side edges will get trimmed to a slight angle when you get to installing them, the fuselage curves Yes, bookmark Tom Tugan's site. His links make it *real* easy to drill down to the chapter at hand. Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
Cozy1200 Posted February 4, 2008 Share Posted February 4, 2008 Heads up on F22... Before laying out and cutting F22, flip to last page of CH4. The first photo shows a different method of laying out F22. It shows that it's possible to make F22 out of one piece of foam instead of the plans method of two. It involved more work to micro the pieces together, but at $20 a sheet it is worth considering. I didn't notice the photo until I finished the part. Quote Drew Chaplin (aka the Foam Whisperer) --- www.Cozy1200.com - I'm a builder now! --- Brace for impact... Link to comment Share on other sites More sharing options...
killerb1971 Posted February 4, 2008 Author Share Posted February 4, 2008 Today I completed the first layup on the seat back. It went great. I had to wait unil today to start it because I didn't get my peel ply tapes until this morning. I made the hardpoint layup last night. It ended up using 25 layers to make the 1/4" thickness. I used the scrap foam from the landing gear cutouts as my gauge, covered it in plastic, smoothed out all the air bubbles between the plastic and the layup, placed a smooth board over it and weighted it down with a heavy flywheel from a big block chevy. It came out great except for one small wrinkle in the very bottom corner from the fold in the plastic. The overall dimensions of the usable smooth part is 10" X 12", so I am ok. It feels great to be making progress! : ) Quote Rob Wiehl COZY MKIV #1521 Link to comment Share on other sites More sharing options...
Neverquit Posted February 5, 2008 Share Posted February 5, 2008 Looks like spilled milk. Beautiful. Quote Link to comment Share on other sites More sharing options...
macleodm3 Posted February 5, 2008 Share Posted February 5, 2008 Yes, looks very nice! You do a nice job of keeping your work area clean! Quote Andrew Anunson I work underground and I play in the sky... no problem Link to comment Share on other sites More sharing options...
