JTest-EZ Progress report
G'day
The weather has again turned too cold to work without heat in the hanger. I have picked-up where I left off on Chapter 11 in the warm room.
I installed the elevators and drilled the canard for the NC-3s and NC-3As. I took a couple of pictures of the layup after the flox was put into the openings to hold the elevators.
I welcome constructive comments...
Thanks for looking;
Jeff
  • 2 months later...
  • Replies 104
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
G'day
I also managed to start the nose. I used a belt sander to sand the foam to shape. I have some pictures of the solid foam nose.
Then I took a hand saw and cut out the inside... I have a few pictures also.
I welcome any constructive comments or ideas.
Thanks for looking and Happy Holidays!
Jeff
G'day
I have the nose gear assembly sitting under the warm room work bench. I needed to get the Canard out before I can move the Tub into the room due to space issues.
Yes, I know I did the last part of the Chapter first.... I may regret it I know, but it was also kind of fun to see what it will look like...
I wanted to work on cold area stuff (hanger temps around 40 degrees F) so I worked on the nose shell. Yeah, I may need to make some mods to it, but it is only foam and easy to work with. I hope to get the gear installed in the New Year!
Cheers!
Jeff
