Edge 513 Posted December 4, 2007 Share Posted December 4, 2007 I wish my "Lawn ornament" Was as far along as mr. edge13"s is Yes I mix my epoxy until it looks good. I am using ez 84 so it is really ez to see when it is done. If I took 5 minutes for every cup I made My last 8 hour spar cap layup would have taken 12 hours ez. Ps. Get your mind off body parts and get back in the shop and build the lawn ornament. STeve:D Roger that. [salute] Quote Self confessed Wingnut. Now think about it...wouldn't you rather LIVE your life, rather than watch someone else's, on Reality T.V.? Get up off that couch!!! =) Progress; Fuselage on all three, with outside and inside nearly complete. 8 inch extended nose. FHC done. Canard finished. ERacer wings done with blended winglets. IO540 starting rebuild. Mounting Spar. Starting strake ribs. Link to comment Share on other sites More sharing options...
rickh Posted December 4, 2007 Share Posted December 4, 2007 Update. Apparently 5 minute epoxy cure in five minutes. . . once your past waiting for your first first part to cure (A watched pot ...) Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
Phil Kriley Posted December 4, 2007 Share Posted December 4, 2007 Update. Apparently 5 minute epoxy cure in five minutes. . . once your past waiting for your first first part to cure (A watched pot ...) Rick You might want to read the bottle again. I'm pretty sure that the WORKING time is 5 minutes, and that full cure is quite a bit beyond that. 20 minute epoxy has a working time of about 20 minutes, but doesn't reach full cure for hours. Quote Phil Kriley Cozy #1460 Chapter 13 - nose Right wing done - working on right winglet. Link to comment Share on other sites More sharing options...
rickh Posted December 4, 2007 Share Posted December 4, 2007 Phil: You might want to read the bottle again. I'm pretty sure that the WORKING time is 5 minutes, and that full cure is quite a bit beyond ... Five minutes, it's gum stage. 5 minute set, 15 minutes to handle, 1 hour to fully cure (though I doubt this, just because) On topic: I don't stir for 5 minutes Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
TMann Posted December 4, 2007 Share Posted December 4, 2007 As a side note: Dave R (Berkut) also incorprates superglue with accelerant for those 5-min. epoxy operations. I never saw that one before but that's a tip on his video. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
