mak790 Posted February 17, 2007 Share Posted February 17, 2007 If you wouldn't mind looking to see if TERF mentions the source for the revised layup schedule I would certainly appreciate it. If you do mind... well... that's Ok, tooUnfortunately I haven't found any more info beside that what I said before TERF contains scans of Rutan Long ez plans (first edition) But I think I found better solution and I'll send u private email tomorrow with more details so we can clarify this case.Mak Quote Link to comment Share on other sites More sharing options...
raiki Posted February 17, 2007 Share Posted February 17, 2007 Guys Looking at my TERF plans, the LongEZ layup pictures that MAK posted are correct. However the schedule he posted doesn't match the schedule in the plans, nor does it match the picture. You'll also notice the AeroCanard pictures and schedules don't match. I could be missing something. MAK could you set me straight. I'll try and extract one or two pictures of the plans and post them, or maybe the whole section of the spar caps. MAK, perhaps you do the same so we can be sure all TERF cds are equal ??? Quote Adrian Smart Cozy IV #1453 Link to comment Share on other sites More sharing options...
Jon Matcho Posted February 17, 2007 Share Posted February 17, 2007 Please tell me WHERE in the "TERF plans" layup schedule does NOT match the original Long-EZ schedule. Which line item(s) is/are incorrect? What should the schedule be (WITHOUT CANARD PUSHER ADJUSTMENTS)? I have Long-EZ March 1980 - First Edition plans and they match what is in the TERF CD. I recognize that the Canard Pushers have not been applied. I'm missing something here... There's nothing that TERF did to the text or images in the plans -- mainly they just scanned and burned a CD. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
--D-- Posted February 18, 2007 Share Posted February 18, 2007 NO WORRIES, ALL ... It was a bad read on my part, Jon. My confusion also appears to have bled over onto raiki, too. Sorry about that. The pdf that Mak posted was for the wing (top) AND the centersection spar (bottom).... which he CLEARLY called out in a later post. I simply missed it. So, the graphic and the table don't match for good reason... because they're for two different things (thank goodness!!!!). My apologies for the fire drill... but I'm very pleased to know that I don't have to redo my wings and/or spar! D Quote Link to comment Share on other sites More sharing options...
mak790 Posted February 18, 2007 Share Posted February 18, 2007 I'm happy that everything is ok with my and your plans. I'm very pleased to know that I don't have to redo my wings and/or spar!Nice to hear that you don't have to redo your wings and/or spar Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted February 18, 2007 Share Posted February 18, 2007 A happy ending! For a moment I was worried that TERF's OCR process mangled the Long-EZ plans (in the same way the AeroCanard plans mangle the Cozy plans here and there (AeroCad is now constantly fixing issues relating to less-than-perfect OCR). An OCR process was actually NOT used for the Long-EZ plans. The bad is that you cannot search text in the plans. The good is that the plans are assured to be faithful reproduction of the originals. Finally, I think that RAF ONLY released First Edition Long-EZ plans (March 1980). Any and all updates are in the Canard Pushers. Good point about the Canard Pushers though -- read ALL Canard Pushers and update your plans religiously. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
zies8 Posted February 18, 2007 Author Share Posted February 18, 2007 So commrades; In the end the answer to the original question ............ ........." why can the cozy claim a higher useful load than the Long Ez" is simply because the Cozy and Aerocanard plans have heavyer Shear Web and Spar Cap layups. Therefore my original idea to use Cozy IV wings on a Long Ez would work to create a higher useful load Long Ez. Thank you........ Comments on the idea of using Cozy wings on a Long Ez would be appreciated. ...................................Mike Quote Link to comment Share on other sites More sharing options...
Wayne Hicks Posted February 18, 2007 Share Posted February 18, 2007 Well, there's the matter of the beefier landing gear on the Cozy....and the stiffer engine mounts....and beefier nose weel. It's not just the shear webs and spar caps. Quote Wayne Hicks Cozy IV Plans #678 http://www.ez.org/pages/waynehicks Link to comment Share on other sites More sharing options...
zies8 Posted February 18, 2007 Author Share Posted February 18, 2007 So the modification list for the "Heavy Hauling Ez" would be: 1. Fuselage width increase 4". 2. Long nose to help with W&B. 3. Cozy landing Gear. 4. Cozy wings. 5. O-360 or O-540. with Cozy engine mounts 6. Cozy nose gear. Is the engineering for the "Heavy Ez" doable due to the design parameters that are existing in the two planes and the fact that most of these mods have already been implemented on other aircraft (though not in that particular combination)? Opinions?............. Quote Link to comment Share on other sites More sharing options...
raiki Posted February 18, 2007 Share Posted February 18, 2007 The "heavy Hauling EZ" sounds like a very good idea, ans the things you note doing would acheive it. I still think using Cozy IV plans but making a 2 seat fuse would be the best approach, but with the existance of the OpenEZ will be more expensive. ($500 plans). That being said $500 is not a lot when you consider what you will be spending on the whole plane. The reason I think it would be better is the Cozy plans have been updated with mods (assuming you buy new, but you will still need newsletter changes). Also these plans already contain a tried and tested wing with a higher gross. Anyway, thats just my opinion. Quote Adrian Smart Cozy IV #1453 Link to comment Share on other sites More sharing options...
Wayne Hicks Posted February 18, 2007 Share Posted February 18, 2007 You probably didn't mean what you said, but just in case. (1) The Long-EZ canard (GU version) has been statically load-tested. (2) VariEze winglets have been statically load-tested. (3) The Long-EZ wings, Cozy III wings, and Cozy IV wings have never been statically load-tested. However, there have not been any structural failures in flight. So read into that what you will... Quote Wayne Hicks Cozy IV Plans #678 http://www.ez.org/pages/waynehicks Link to comment Share on other sites More sharing options...
Wayne Hicks Posted February 18, 2007 Share Posted February 18, 2007 Oh, if a heavy hauling EZ is what you're after, the Berkut has been described as a Long-EZ on steroids. It is 8 inches wider than the Long-EZ. Just a data point for you. Quote Wayne Hicks Cozy IV Plans #678 http://www.ez.org/pages/waynehicks Link to comment Share on other sites More sharing options...
zies8 Posted February 18, 2007 Author Share Posted February 18, 2007 Raki; Thank you for your opinion!!! I am considering seriously the route you suggest. Wayne: I agree that the berkut is a great choice. The fact that a kit costs somewhere in the $60k range is jus too much for me to bite off. Maybe a berkut project that is in the early stages that is incomplete could be an option. One with just the fuselage done without the later parts of the kit purchased. If the Berkut has an increase in the fuselage of 8" that would be perfect. I did not know that the Berkut was 8" wider. Mike Quote Link to comment Share on other sites More sharing options...
mak790 Posted February 18, 2007 Share Posted February 18, 2007 (3) The Long-EZ wings, Cozy III wings, and Cozy IV wings have never been statically load-tested. However, there have not been any structural failures in flight.I'm afraid you are wrong;) Quote Link to comment Share on other sites More sharing options...
Juan Rivera Posted February 22, 2007 Share Posted February 22, 2007 Yup the first photo was from my friend in switzerland Quote Link to comment Share on other sites More sharing options...
mak790 Posted February 22, 2007 Share Posted February 22, 2007 Yup the first photo was from my friend in switzerlandAre u talking about Hans Georg Schmid and his famous HB-YCT?http://www.experimental.ch/SwissMade/HG_Schmid/MillenniumFlight/default.htm Quote Link to comment Share on other sites More sharing options...
Beastus_Maximus Posted July 27, 2008 Share Posted July 27, 2008 The Long EZ is a super SUPER aeroplane! I can't shut up about it. :-) I have seen your plane around, it is a damn nice bird. I really like the nose extension you did, it seems well thought out. Quote We make no mistakes, ONLY INNOVATIONS! Link to comment Share on other sites More sharing options...
