Lowlevldevl Posted January 3, 2007 Share Posted January 3, 2007 Hi, I bought myself a Long-EZ last year and the previous owner covered the interior in white boat carpet. I'd like to strip it out and paint the interior. Getting the carpet out will be easy but does anybody know of a product which is safe to use on our foam core aeroplanes that will effectively remove the contact cement that its stuck down with? Cheers, Don Quote Link to comment Share on other sites More sharing options...
Wayne Hicks Posted January 3, 2007 Share Posted January 3, 2007 Use a heat gun. Gently heat the patch of cement, then gently lift it off with a scraper or putty knife. All the other google methods involved using solvents. Don't try those. Quote Wayne Hicks Cozy IV Plans #678 http://www.ez.org/pages/waynehicks Link to comment Share on other sites More sharing options...
Radioflyer Posted December 22, 2007 Share Posted December 22, 2007 I will have the same chore to do as my interior is covered with leather that has worn too much, faded and turned ratty. The heat gun is one idea for removal, but I worry that it would be too easy to melt the fibreglass/foam. Maybe it is not that much of an issue. I'll have to try it. What I was planning to do was to use a rubber eraser and rub it off. I've seen some power drill wheels in some tool catalogues designed to take rubber cement off car parts and they seem to be hard rubber erasers. If you get to try either method before I do, please post results. Quote Link to comment Share on other sites More sharing options...
TMann Posted December 22, 2007 Share Posted December 22, 2007 Formica makes a solvent that goes with their contact cement for the laminate tops. Anyway, it works real well for removing contact cement from the laminate and surrounding area. Best stuff I've found but it will remove paint & finish from just about anything else as well. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Big Steve Posted December 22, 2007 Share Posted December 22, 2007 I would be really careful using a solvent if it will melt glue I bet it will melt foam. Of course a hollow airplane is lighter than one filled with foam. My .02 STeve Quote Steve Harmon Lovin Life in Idaho Cozy IV Plans #1466 N232CZ http://websites.expercraft.com/bigsteve/ Working on Chapter 19,21 Link to comment Share on other sites More sharing options...
Rob Wright Posted December 23, 2007 Share Posted December 23, 2007 maybe soda blasting would take it out. Quote Link to comment Share on other sites More sharing options...
