--D-- Posted December 11, 2006 Share Posted December 11, 2006 Just priced 10-32 EZ Point studs from ACS at over $3 a piece!! Wandered over to www.mcmaster.com and found stainless "Perforated Base Binding Studs" priced at a little over $12 for a pack of 10. Multiple lengths, multiple stud sizes available. The perforated base also gives the flox somewhere to oooze through for a better bond. McMaster has base nuts for about the same price. D Quote Link to comment Share on other sites More sharing options...
Jerry Schneider Posted December 11, 2006 Share Posted December 11, 2006 I use Click Bond bases from JD Newman @ $.50 ea. Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
Canardale Posted November 8, 2019 Share Posted November 8, 2019 Jerry, can you please provide a link for JD Newman? Searches turn up this thread and a trucking company. Quote Link to comment Share on other sites More sharing options...
Canardale Posted November 8, 2019 Share Posted November 8, 2019 Did not notice this was a very old thread...sorry folks. 1 Quote Link to comment Share on other sites More sharing options...
Voidhawk9 Posted November 8, 2019 Share Posted November 8, 2019 JD's site is here: http://infinityaerospace.com/product-category/other/ Though rumour is he may be in poor health and unreachable at the moment. Hopefully that resolves soon. You can get them from the Cozy Girrrls too: http://www.cozygirrrl.com/aircraftparts.htm Quote Aerocanard (modified) SN:ACPB-0226 (Chapter 8) Canardspeed.com (my build log and more; usually lags behind actual progress)Flight simulator (X-plane) flight model master: X-Aerodynamics (GMT+12) Link to comment Share on other sites More sharing options...
Jon Matcho Posted November 8, 2019 Share Posted November 8, 2019 It's totally fine to reply to old threads. Feel free! Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
A Bruce Hughes Posted November 16, 2019 Share Posted November 16, 2019 I have used many from the Cozzzy girls. I told them how to improve them but they declined. When I use one, I first grind the bonding surface with a Dremel to rough it up, then notch it so the bonding surface has a shape between round and square or other odd shape. If that is not done, it will later rotate is you tighten the nut too much or have to loosen it. McMaster has good ones. Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted November 16, 2019 Share Posted November 16, 2019 9 minutes ago, A Bruce Hughes said: I have used many from the Cozzzy girls. I told them how to improve them but they declined. When I use one, I first grind the bonding surface with a Dremel to rough it up, then notch it so the bonding surface has a shape between round and square or other odd shape. If that is not done, it will later rotate is you tighten the nut too much or have to loosen it. Those are good tips, but CG Products buys in bulk and re-sells. They're not the manufacturer, so I don't blame them for doing that with each and every stud they sell. Lotta work for little return. 11 minutes ago, A Bruce Hughes said: McMaster has good ones. Nice, I didn't know they had comparable items (although I should have -- they have everything)! https://www.mcmaster.com/studs Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Barry Posted November 17, 2019 Share Posted November 17, 2019 Looks like the McMaster version has anti rotation flats... Quote Link to comment Share on other sites More sharing options...
Canardale Posted November 17, 2019 Share Posted November 17, 2019 The McMaster versions have no strength rating. Cozy appear to be AN, which I am guessing are to aircraft standards. Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted November 17, 2019 Share Posted November 17, 2019 9 hours ago, Canardale said: The McMaster versions have no strength rating. Cozy appear to be AN, which I am guessing are to aircraft standards. I noticed that too, but was unable to find that information on the Click Bonds website either, and I am already using them. I do the same things as Bruce mentioned. I wouldn’t have much concern about using the McMaster items, but your point and concern is entirely valid. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted November 17, 2019 Share Posted November 17, 2019 2 hours ago, Jon Matcho said: I noticed that too, but was unable to find that information on the Click Bonds website either, and I am already using them. I do the same things as Bruce mentioned. I wouldn’t have much concern about using the McMaster items, but your point and concern is entirely valid. Most of the clickbond specs (in a catalog) are available at The Flight Shop (https://www.theflightshop.com/Download/TheFlightShopCatalogrev12.pdf). For non structural mounting (tie-wraps, etc.) I wouldn't have a problem with the McM parts. But for anything that's safety related (mounting A/P servos, control system components, etc.) I wouldn't go near them with a 10 ft. pole. 1 Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
