Choosing a length for the canard
Lengthy cut'n'paste from an old CP (from when there were about 20 Varieze flying) which leads me to understand something I didn't before - a heavier motor and a longer canard are both ways toward an aft c of g:
"Those of you who do have the heavier engines and alternators are
finding that the nose weight needed to get the cg forward is cutting
into your useful load, already reduced with the heavy engine. If this
were a conventional airplane there wouldn't be much you could do, short
of moving the engine or wing. But, since the VariEze has two widely
separated, lifting wings, the allowable cg range can be shifted by
shortening or lengthening the canard. Thus a "tailheavy" airplane can
be made to fly "nose-heavy" merely by sawing off canard span, making no
change to actual cg! This can be done only up to a point, where
directional stability is lost as cg is moved aft. We have tested the
flying qualities and confirmed that the canard/elevator is free from
flutter at two canard spans - 150" as shown in the plans and 142" which
is obtained by sawing 4" off each tip. If 4" is sawed off each canard
tip (142" span) you can move the allowable cg range aft 1.2 inches.
This is equal to adding 15-lb weight in the nose at F.S. 5.
Let's look at a couple of examples to see what this canard trim can do
for you. Assume you weigh 170 lb and you are using an 0-200 with
alternator and a small battery. When you do your weight and balance
you find you will need 30-lb ballast in the nose to get to the nose
heavy condition (preferred for low pitch sensitivity) for first flight.
Then later you can remove 1/2 the ballast, but will have to carry 15 lb
of lead in the nose for the life of the airplane. If you trim the
canard you will find that you only need 15-lb ballast to get to the
forward cg you need for first flight. Then, when you are comfortable
with the stick forces you can remove all ballast and have the best
useful load and a mid to aft cg. Thus, trimming the canard has
increased your useful load by 15 lb!"
Also showing more tolerance toward modification then, probably until the death toll mounted...
Mark Spedding - Spodman
Darraweit Guim - Australia
Cozy IV #1331 -  Chapter 09
www.mykitlog.com/Spodman
