Steve Innova Posted April 3, 2004 Share Posted April 3, 2004 Hi, Is the temporary firewall in chapt. 4 actually temporary? Will it be replaced by something else later? If so, do I need to order plywood from Wicks, or can I use something from Home Depot? Stephen Quote Link to comment Share on other sites More sharing options...
Dave Clifford Posted April 3, 2004 Share Posted April 3, 2004 The HD stuff is fine for this. Quote Dave Clifford "The Metal Man" Musketeer Vise grip hands and Micrometer eyes!! Cozy MKIV Plans #656 Link to comment Share on other sites More sharing options...
John Slade Posted April 3, 2004 Share Posted April 3, 2004 Is the temporary firewall in chapt. 4 actually temporary? Yep. You throw it out later and use some nice norwiegan pine or something for the real thing. HD is fine. Just be sure it's flat. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Steve Innova Posted April 3, 2004 Author Share Posted April 3, 2004 John, Where did you find a thermostat (for the epoxy pump box) that went up to 120 degrees? I looked at HD & could only find things that went to approx 90. Quote Link to comment Share on other sites More sharing options...
shender1 Posted April 4, 2004 Share Posted April 4, 2004 good question...I couldnt find one either..the closest thing I found was a reptile tank heater at a pet store...i didnt buy it...it was 50 bucks Quote I'm not aware of too many things. I know what I know if you know what I mean. Link to comment Share on other sites More sharing options...
Dave Clifford Posted April 4, 2004 Share Posted April 4, 2004 We are using a thermostat switch that is used for kerosene torpedo heater. It works great. Quote Dave Clifford "The Metal Man" Musketeer Vise grip hands and Micrometer eyes!! Cozy MKIV Plans #656 Link to comment Share on other sites More sharing options...
John Slade Posted April 4, 2004 Share Posted April 4, 2004 $1.20 in Home Depot. Neat little device called a "light bulb". I changed wattage in summer & winter. Simple, cheap and effective. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Rui Posted April 7, 2004 Share Posted April 7, 2004 I used some Baltic Birch plywood for the temp firewall. It's available from a local supplier called Windsor Plywood. You may find such a supplier in your area. Actually Trevor Howard recommended this to me. It is flat and smooth unlike the crap you get at HD and other such places. As for the thermostat I used the 90 degree baseboard heater types and turned the adjustment screw. Its shipped with some sort of loctite type material with the factory setting, but its easy break the lock. Quote Rui Lopes Cozy MkIV S/N: 1121 Link to comment Share on other sites More sharing options...
dust Posted April 7, 2004 Share Posted April 7, 2004 you are gonna have a real laugh when you see how little the temp firwall matters enjoy the build dust Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
David Swain Posted April 8, 2004 Share Posted April 8, 2004 I was wondering......thermostat.....I have an old water bed out in the garage with a pad type heater and THERMOSTAT......Hmmmmm..... Any thoughts...?? Quote David Swain Watch thine airspeed, least the ground come up and smite thee....... Link to comment Share on other sites More sharing options...
mplafleur Posted April 8, 2004 Share Posted April 8, 2004 A waterbed thermostat is commonly used for the hot box. Quote Mike LaFLeur - Cozy MkIV #1155N68ML Link to comment Share on other sites More sharing options...
