noodles Posted February 26, 2004 Posted February 26, 2004 Hello, I was wondering if someone knows the location or information for the Rotisere stand. Are there any plans or do I wing it. I've tried checking the achives but can't seem to locate the correct name for the "spinny" thing. I was looking to make one. Thanks, Nathan Quote Cozy IV project. Redheaded Stepchild of The Canard Community
dust Posted February 26, 2004 Posted February 26, 2004 Clifford made GREAT rotiseries for us, welded bed frame angles, cheep steel, with 1/2 in square tube on top with a nut welded on and drilled through to lock fuselodge in any position and screwed 1/2" pipe flange to each end of fuselodge with 1/2 inch pipe into the 1/2" square tube, all of it mounted onto 12 and 10 foot 2x4's clifford, you got a pic you can post of your great work enjoy the build dust Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/
Dave Clifford Posted February 26, 2004 Posted February 26, 2004 I made ours(two sets) out of scrap angle iron bed frames trash picked. I built them tri-pod style with a pipe in pipe about 6" long welded at the top. I used a pipe flange from home depot mounted to the inner pipe which I bolted to the fire wall and the instrument panel in a center line. I welded a 3/8" nut on top of both outer pipes and drilled and tapped through it. This allowed a bolt to lock down the fuselodge in any position of rotation. The welded tripods were fastened down on 2 long 2"X4"s that rested on the floor. We were able to slide the two tubs around and rotate them in any position we needed. Costs were around $10.00 for each set. Both sets were given away to other builders and are still in use. I ALWAYS have a few bed frames in stock for the steel. Quote Dave Clifford "The Metal Man" Musketeer Vise grip hands and Micrometer eyes!! Cozy MKIV Plans #656
Cozy1200 Posted February 27, 2004 Posted February 27, 2004 You can see one on Jim Springer's website. http://www.sixspringers.com/Cozy/cozy.htm Quote Drew Chaplin (aka the Foam Whisperer) --- www.Cozy1200.com - I'm a builder now! --- Brace for impact...
rmaddy Posted February 27, 2004 Posted February 27, 2004 You can see mine at http://www.maddyhome.com/cozy/chapter?c=7&s=5 Quote Rick Maddy Denver, CO Cozy Mk IV #824 - Chapter 18 http://www.maddyhome.com/cozy
Joe Patterson Posted February 27, 2004 Posted February 27, 2004 So, Am I understanding this correctly??????????? You can loosn a few bolts, and rotate the fuselage for work on all sides??????????? I saw my first "Star-Ship" today........Wow , These Cozy's are beautiful. http://groups.msn.com/TaosHouse/aroundthehouse.msnw?action=ShowPhoto&PhotoID=114 JO-Z Quote [email protected] I am Building a Jo-Z IV StarShip. What Do YOU Want?
noodles Posted February 27, 2004 Author Posted February 27, 2004 Thanks guys, I appreciate the info. Right now its sitting on saw horses right now and it's a paint to get in there. Rick yours seems to be the most complete with little to no modification to the tub. When did you end up finally removing the rotiseri? Quote Cozy IV project. Redheaded Stepchild of The Canard Community
rmaddy Posted February 27, 2004 Posted February 27, 2004 I removed it after I finished the interior work in chapter 8. BTW - while mine worked just fine, it wasn't the most stable in the world. It did it's job and I took it apart never to see life again. Along these lines, I've seen some builder go to some extreme lengths to over design jigs and the like. If you plan on building more than one plane it probably makes sense but most of us use the jig once and take it apart. Don't waste a lot time over doing this sort of thing. Enjoy. Quote Rick Maddy Denver, CO Cozy Mk IV #824 - Chapter 18 http://www.maddyhome.com/cozy
noodles Posted February 28, 2004 Author Posted February 28, 2004 Rick, You did a great job on the content for your website. When I can't seem to find specific information your site always seems to have a picture of my problem and text describing how you resolved the issue. Keep up the good work. Nathan, Quote Cozy IV project. Redheaded Stepchild of The Canard Community
