dust Posted October 13, 2003 Posted October 13, 2003 Can i say more than that, we are assemblying the items we need for the fuel system back to the firewall. We are using 1/2 inch OD tubing to and from a double throw valve at the center position and also need to install sending units in the tank, so whats who using??? Enjoy the build (we are) Mike Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/
John Slade Posted October 13, 2003 Posted October 13, 2003 I got mine from recreationalmobility.com http://www.recreationalmobility.com/cgi-bin/recreation/FalconFuel.html I'm not sure which guages they work with other than falcon Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net
chuckthedog Posted October 13, 2003 Posted October 13, 2003 check out Composite Design. www.compositedesign.com Quote If the phone don't ring. It's me
dust Posted October 14, 2003 Author Posted October 14, 2003 www.compositedesign.com ?? Couldn't find enjoy the fly chuck, while i enjoy the build Mike Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/
dust Posted October 14, 2003 Author Posted October 14, 2003 DAAAAAAA just went to blue mountain and found this Van's makes things that work well for not a lot of money. His capacitive fuel level sensors are simple, elegant and cheap. These modules turn the capacitance into a voltage the EFIS can read. You need one for each sensor, sold as a pair. 140 for the pair Sounds like a plan Any nays?? enjoy the build Mike Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/
chuckthedog Posted October 14, 2003 Posted October 14, 2003 Try www.compositedesigninc.com Quote If the phone don't ring. It's me
dust Posted October 14, 2003 Author Posted October 14, 2003 Well ifin i am relying on blue mountain, i guess i can trust thier stuff. The prices i found were 160 recreationalmobility.com 175 Composite Design And the winner is 140 blue mountain as dealer for vans Enjoy the build Mike Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/
dust Posted November 6, 2003 Author Posted November 6, 2003 OK time to correct this post, i thought blue mountain sold the probes, they don't. What they sell for 140 is a pair or circut boards that takes the 0 to 5 volt signal that the tank unit sends and converts it to what blue mountain can then use. Sooooooooooooo, they recomend units sold by westberg mfg aka westach 1-800-400-7024 12" bendable probes 3955sb-5 and 108.5 each enjoying the design Mike Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/
LargePrime Posted November 7, 2003 Posted November 7, 2003 http://www.frostalarm.com/cat/dp36.html Quote We know who you are...
