Jack Kretmar Posted July 24, 2003 Share Posted July 24, 2003 I'm posting this in the general forum. In aircraft conversions of the rotary engine, you have to add two-stroke lawn mower engine oil to the fuel. Can this make the engine burn "dirty", causing carbon deposit build-up in the combustion chamber and exhaust port areas? It is my understanding that carbon build-up can cause pre-ignition. Is this a factor, and if so, what can be done about it? Jack Quote Jack Kretmar Link to comment Share on other sites More sharing options...
Jim Sower Posted July 24, 2003 Share Posted July 24, 2003 No. Weed eaters and chain saws use a 40:1 mix. Mazdas use closer to 150:1. Additionally, 2-stroke oil is ashless. Motor oil is not recommended and in fact is discouraged. The Mazda automobile applications have a little pump system that injects a little motor oil out of the pan. Engine failures, far from being caused by deposits, are more likely if the oil injection system fails. That's why rotary powered airplanes mix it with the gas. Also, the mixture from the injector is not at all uniform. Motor oil, which is only marginally suitable but is the source in cars, works fine. 2-stroke oil, which can be bought for a maybe 5 bucks gallon, is great. Marvel Mystery oil is also popular. For perspective, 1 oz (carry a measuring cup with you) per gallon gives you a 128:1 mixture; one quart would work for a cozy tank full. Different folks have different ideas ranging from 120:1 to 180:1 mixture. Join Tracy Crook's Rotary list and surf the archives. Quote ...Destiny's Plaything... Link to comment Share on other sites More sharing options...
Jack Kretmar Posted July 25, 2003 Author Share Posted July 25, 2003 Jim, Thanks for your reply which answered my question exactly. The oil "problem" is no problem at all. I'll certainly join Tracy Crook's group. Jack Quote Jack Kretmar Link to comment Share on other sites More sharing options...
rx8khan Posted June 5, 2009 Share Posted June 5, 2009 ok i have a 04 mazda rx8 i was just wondering about the 2stroke oil is it ok to use it on the rx8? and second do i use it in the gas or the oil? Quote Link to comment Share on other sites More sharing options...
