Blackhawk D Posted July 5, 2003 Share Posted July 5, 2003 My understanding is that a plain paper 8 ounce cup, no wax or other coatings, is the best choice for mixing epoxy prior to use. I understand that they are available from the normal suppliers, but I would think I should be able to find a local source. Problem is that I have been unsble to locate any. I have tried Wal-Mart, K-Mart, Ace Hardware, paint supply stores, commercial paper suppliers and almost anyone that sells paper products of any kind and the answer is HUH? Seems plastic or foam cups are the norm for hot/cold liquids. All of the paper cups I have found are coated. I cannot find a local supplier for the type menttioned in the plans - Lily 8SN1 Perhaps I have misread or misunderstood, so hopefully someone can help. Do I need to worry if the cup is coated? Is a plastic coating OK? Is wax OK? Does anyone know of a normal outlet for a plain paper uncoated cup? What is everyone using to hold the epoxy out of the pump? Thanks for the info. Quote Darrell Link to comment Share on other sites More sharing options...
rmaddy Posted July 5, 2003 Share Posted July 5, 2003 Wax is supposed to be bad as it can contaminate the epoxy. Don't used waxed paper either - use 4mil plastic. I just buy big sleeves of the paper cups from Wicks as needed. I've never tried to locate them locally. Not sure if plastic cups are OK or not. I don't know of a problem but I don't know for a fact that they are OK either. Quote Rick Maddy Denver, CO Cozy Mk IV #824 - Chapter 18 http://www.maddyhome.com/cozy Link to comment Share on other sites More sharing options...
Dave Clifford Posted July 5, 2003 Share Posted July 5, 2003 Plastic cups are perfectly fine for mixing. We get ours from Gordans Food Service. These are non coated. They are the plastic containers you get from the deli. They come in various sizes. Before we started building I searched for an alternate supplier other than Wicks, ect,,. The plastic cups are a tenth the cost of paper, both from aircraft suppliers and food service suppliers. Get your tounge depressors from a medical supplier and specify Non Sterilized. Quote Dave Clifford "The Metal Man" Musketeer Vise grip hands and Micrometer eyes!! Cozy MKIV Plans #656 Link to comment Share on other sites More sharing options...
mplafleur Posted July 6, 2003 Share Posted July 6, 2003 Thanks for the input Clifford. We used paper and plastic when I work at the fiberglass plant in the '80s. I have a discount card for GFS for 10% off. Too bad you can't get resin and glass there. Quote Mike LaFLeur - Cozy MkIV #1155N68ML Link to comment Share on other sites More sharing options...
Wayne Hicks Posted July 6, 2003 Share Posted July 6, 2003 Dixie cups (the kind used in the bathroom for mouthwash) are great for those little jobs requiring only a few squirts of epoxy. (And there are LOTS of little jobs!) Cheap, disposable, no cleanup afterward. .....Wayne Hicks Quote Wayne Hicks Cozy IV Plans #678 http://www.ez.org/pages/waynehicks Link to comment Share on other sites More sharing options...
Jerry Schneider Posted July 6, 2003 Share Posted July 6, 2003 Dave, Could you provide the stock number of the cups you like to use from GFS? It's a big site with tons-o-cups. Thanks Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
Dave Clifford Posted July 6, 2003 Share Posted July 6, 2003 We use two different sizes: 16 oz. Pro-Kal PK16S-C for regular mixing for lay ups, micro, ect,,at about $3.50 per 50 cups, and then 3-1/4 oz SOLO P325 cups for up to two pump mixes at about $3.75 for 200 cups. Thane provides our toungue depressors,,,I hope they have not been used first!! Quote Dave Clifford "The Metal Man" Musketeer Vise grip hands and Micrometer eyes!! Cozy MKIV Plans #656 Link to comment Share on other sites More sharing options...
Norm M Posted July 8, 2003 Share Posted July 8, 2003 I used the 9 ounce plastic cups from Walmart or Sam's Club. The brand I currently have is from Praire Packaging, model 9-C. They are clear PETE, about 2.25 diameter at the bottom, 3.75 diameter top, 3 inches tall. They work real nice with the paint mixer that I use for mixing resin. Popsicle sticks also work, but not as fast. The biggest I ever mixed was in a 32 ounce uberBigGulp cup from 7-11. Used that a couple times on the wing layups. But most of the time was done using the 9 ounce cups. For mixing dabs of 5 min epoxy I picked up used communion cups from church. Rinsed them out, and they work nice for about a teaspoon (or less) of 5 minute. For mixing the West system filler, I used a 5 gallon pail with a drywall paddle. Much easier than the superfill stuff that I did. But you gotta be fast with getting it spread out! Regards- Norm Quote Link to comment Share on other sites More sharing options...
marcusc Posted July 22, 2003 Share Posted July 22, 2003 I have found the 4oz nowax cups at SAMS and also the clear plastic 8oz cups Quote Marcus AR Collins Cozy Mark IV Milwaukee, WI Link to comment Share on other sites More sharing options...
