Jerry Schneider Posted June 24, 2003 Share Posted June 24, 2003 I'm in the process of assembling the aileron torque tubes/bearings/what-not.... and I've noticed a considerable amount of "slop" in the fit of the torque tube to universal joint when using the 3/4" x .058" tubing (CS151). Whereas if I use .065" wall tubing, it fits like a glove. Is this to allow for a layer epoxy primer paint or something else I haven't read about yet? TIA Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
John Slade Posted June 24, 2003 Share Posted June 24, 2003 Something sounds wrong here, Jerry. I don't remember any slop. Check you've got the right U joints and pipe. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Jerry Schneider Posted June 24, 2003 Author Share Posted June 24, 2003 I definitely have the right stuff... although I'll check it again this evening.(The 5th time) Maybe the term "considerable slop" was over over kill. The joint fits the thinner walled tubing "a little loosely", but they fit the thicker wall tubing perfectly (while adding <1 oz of weight). The more I think about it, I may just paint the interior of the plans tubes and be done with it. (Corrosion protection ) John, did you.. or anyone else out there for that matter, paint the torque tubes? Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
Wayne Hicks Posted June 24, 2003 Share Posted June 24, 2003 Dear Skip: I too had a fair amount of "slop" between the tubes, universal joints, and bearings. "Slop" being defined as less than perfect, machined fit, but not so wobbly that I questioned whether or not I had the right parts. All the slop went away after tightening the bolts. I did have a good surface to surface fit between the aileron cranks on the firewall and their bronze bearings (the ones that are floxed into the firewall). For corrosion protection, I alodined the aluminum tubes and sprayed the insides of the steel tubes with that green-colored paint (zinc-chromate, I forget what it's called). I will powder coat all outer tube surfaces. Probably overkill for where I live, But definitely something I'd consider if I lived in humid Florida. ============ Wayne Hicks Cozy IV Plans #678 Quote Wayne Hicks Cozy IV Plans #678 http://www.ez.org/pages/waynehicks Link to comment Share on other sites More sharing options...
Jerry Schneider Posted June 24, 2003 Author Share Posted June 24, 2003 Wayne, Your description exactly describes my experience. Thanks for the comeback!. Once again, the old "Stop Worrying and Just Follow the Plans" monster rears it's ugly head. Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
