replacement composite hinge pins?
Are you talking about the teflon hinge kit offered by Gary Hall?
His Experimental Aircraft AILERON / RUDDER HINGE RETROFIT KIT prevents additional wear on experimental aircraft hinges. The hinge kit fits any MS20001-P3, '-P4', '-P5', or '-P6' extruded aluminum piano hinge that is specified for use on the Long-Ez, E-Racer, VariEze, Defiant, Cozy, Solitaire, Lancair, Pulsair or Glasair ailerons and/or rudders. The kit contains enough Teflon spaghetti tubing and a special high grade stainless spring steel wire for all the hinges used in the ailerons and rudders.
You can contact him at:
GARY A. HALL
Work: (954) 979-9494
FAX: (954) 975-8018 (USlan Corp)
gary.hall@uslan.com
http://www.uslan.com/hinge-kit.html
Wayne Hicks
Wayne Hicks
Cozy IV Plans #678
  • 18 years later...
Hi all:
 I just found this post.
I wanted to let anyone reading this that I bought the hinge pin repair kit business from Gary Hall.
My contact info:
James Russell
Electric Shadows, Inc.
841 Old Gardiner Rd.
Sequim, WA 98382
USA
(817) 691-5465 C
fshort@flash.net
I have attached a info sheet.
Regards,
James
Hinge Repair Kit COVER PAGE (rev F).pdf
  • Thanks 1
James Russell
Sequim, WA 98382 USA
