Using Clickbonds to Attach Ailerons to Wings
Wayne Hicks
I'd like to report my positive experience with using Clickbonds to attach the ailerons to the wings.
A Clickbond is a screw with a wide thin base instead of a screw head. You drill the holes through the wing's spar box area and though the aileron hinge halves as per plans. The Clickbonds are floxed in place and you put 1 layer of BID over that. What you end up with is no visible screw heads sticking above the wing surfaces. A very clean installation. I drilled the Clickbond bases and inserted a very small rivet to ensure the bases won't turn.
I've attached a picture. The picture is taken before I drilled the holes for the small rivets.
Wayne Hicks
Wayne Hicks
Cozy IV Plans #678
