Cozylover Posted December 28, 2002 Share Posted December 28, 2002 Hi Canardiens, I'm in the process of buying a COZY 3, with a O235 engine. Only need to do the inspection of the aircraft and fly it! Can anybody help me with a list of the things to be checked on a "pre-purchase" inspection for the COZY 3? Any specific weak points I should know about? All info is more than welcome, but I'm a bit in a hurry...leaving in 24hrs or so! So, if you guys can help me, please mail: flybjorn@emirates.net.ae Thanks and a Happy 2003 to all of you, COZYLOVER Quote Flying was my first love and it will be my last one! Link to comment Share on other sites More sharing options...
LargePrime Posted February 10, 2003 Share Posted February 10, 2003 I wanted to give this thread a bump cause i was wondering if there was any info out there on what to look for. I was really considering buying a project. I dont imagine i am the first or the last. I thought if we could get this info in one area and expose the ideas to peer review we would get a good idea on what to look for. So what would you look for? Quote We know who you are... Link to comment Share on other sites More sharing options...
John Slade Posted February 10, 2003 Share Posted February 10, 2003 Sorry. I responded direct with the following. I'm sure others could add to it. The ideal would be to take an experienced composite builder with you on the inspection. If this is not possible, then here are a few things to look out for, most of which will be obvious. Good luck. If you have the opportunity, take some digital pictures and post them for comments. Bottom line: If it flys well, looks good and the price is right, you'll probably love it. You might call Nat Puffer (designer) at 480-981-6401. Get the serial number. Nat might know the history of the airplane. He may also be able to point you to a nearby builder who can look at it for you. Finish: How straight are the trailing edges of wings, elevator, rudders How smooth is the finish - look for minor bumps and dips in the paint Look particularly around the winglet / wing attach, strake / fuselage join. How even and smooth is the wing leading edge? Structure: Lift the wings. Any play? Lift the canard. Any play? Look at the canard attach tabs Main wheel strut near the wheels - any sign of heat? condition of prop look at aileron / elevator gap - 1/8 inch? elevator balance should be checked at some point before flight (not trivial on a casual inspection) any sign of structural repairs? Controls: Any lag? any side movement of bearings in wing roots? Equipment: Nose Retract - manual or auto. If manual, has it been reversed Panel - age of radios etc. Wiring: How neat is it type of connections Engine: total time since last overhaul who did the last overhaul How professional does the installation look? Any automotive hoses / hose clips? ignition system - mags? mag drop? condition of oil? Performance: what is the gross weight? Take off roll gals / hr at cruise max speed minimum speed and performance below minimum - does it bob nicely? trim stability - does it return to cruise when control pulled / pushed sharply? landing speed brakes - stopping capability are the elevators in trail during cruise? are the rudders in trail when at rest? are the ailerons even and in trail in cruise? Where is the C of G under normal loading / full tanks What are weight limits front / back / overall Fuel capacity? Modifications from plans: Ask the owner to point out anything that isnt per plans Note: A modification isn't necessarily bad and most planes will have some innovations - but you should know what's different. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net Link to comment Share on other sites More sharing options...
Nathan Gifford Posted October 31, 2004 Share Posted October 31, 2004 And fresh paint may be there to obscure other problems. Quote Nathan Gifford Tickfaw, LA USA Cozy Mk IV Plans Set 1330 Better still --> Now at CH 9 Link to comment Share on other sites More sharing options...
