mkiv_bldr 10 Posted November 20, 2002 Hi, Guys. Last night when cutting the hole in the fusalage bottom for the landing light I took out a three inch section of one leg of my nav antenna. Is it worth trying to repair by soldering a wire in to connect the two pieces? Should I try to use more copper tape to make to connection? Thanks ! Quote Alan Wirbisky Eden Prairie, MN Share this post Link to post Share on other sites
dust 10 Posted November 20, 2002 I would start the fuselodge over, it's no longer perfect. Why not just put it in the main wing? Mike Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Share this post Link to post Share on other sites
Paul Kuntz 10 Posted November 22, 2002 A call or e-mail to RST might get a quick, technically credible answer to the question of whether or not your antenna is salvageable. If my objective were salvage, I'd replace the plug cut out for the landing light, remove the outer skin from the plug, then enough skin to expose about a half inch of each severed segment, bridge the antenna gap with copper foil soldered between the severed segments, then repair the inner and outer fuselage skins per plans. And, of course, move the landing light somewhere else. If your canard or wings are not yet built, I'd abandon the severed antenna and put a replacement elsewhere. I put two VOR/glideslope antennas in my canard, one on each side of the fuselage. I also put a broadcast FM antenna in one wing, which would be an equally good location for a VOR antenna. If your canard and wings are done, others have put copper foil antennas on top of existing glassed surfaces. They describe putting the foil down, then covering it with one layer of BID (and, I assume, peel ply to get it as smooth and thin as possible). I don't know how they deal with the coax and toroids, but it shouldn't be too difficult to do with only one or two easily-repaired holes in the surface. Quote Paul Kuntz Cozy MKIV England Share this post Link to post Share on other sites
Jim Sower 10 Posted November 22, 2002 My recommendation would turn on which 3" section of the antenna you cut out ~ end, middle, first? 3" off he end shouldn't hurt much ~ just make it your Nav-2 or something. Your primary is GPS anyway isn't it? ) If it's a critical section, you might want to bury a new antenna under one ply of glass. Now I've already told you more than I know ... Jim Quote ...Destiny's Plaything... Share this post Link to post Share on other sites
steve 10 Posted October 17, 2009 My recommendation would turn on which 3" section of the antenna you cut out ~ end, middle, first? 3" off he end shouldn't hurt much ~ just make it your Nav-2 or something. Your primary is GPS anyway isn't it? ) If it's a critical section, you might want to bury a new antenna under one ply of glass. Now I've already told you more than I know ... Jim RST reading said to soder a 14(romex) gage down the foil to complete it. Quote Steve M. Parkins Share this post Link to post Share on other sites
Kent Ashton 239 Posted October 17, 2009 You could put a couple of nav antennas in the wings or canard and use the cut one for a marker beacon or AM/FM radio antenna. It doesn't take much antenna to pick up a marker beacon. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Share this post Link to post Share on other sites
