noodles Posted August 9, 2002 Posted August 9, 2002 Hello, I'm interested in doing some heat transfer calculations. I have some interesting ideas regarding the ever-present cooling issues related to the rotary. I am cozyless and have no available dimensions. I guess you could say I haven't taken the plunge yet. I was wondering if one of you fine aviators could provide me with a rough estimation of the surface area for the engine cowling. All I need is some off the hip estimations I would also like to know what the average wind velocity generated by the prop as it idles. I don't need it after the prop, I need it prior to it. I understand that the velocity will vary as it gets closer. I figure any rough estimate across the engine cowl will be sufficient. Thank you gentleman Quote Cozy IV project. Redheaded Stepchild of The Canard Community
John Slade Posted August 9, 2002 Posted August 9, 2002 Hi, I just measured the custom cowl I built for my 13B powered Cozy IV. See http://kgarden.com/cozy/cowl.htm for pictures. It seemed like 100 sq ft during finishing, but my ROUGH guess at surface area of the upper cowl is 12 sq ft, not counting 4 sq ft of area over the wing roots. The lower cowl has a little less surface area - maybe 10sq ft. plus another 4 sq ft under the wing roots. Hope this helps. John Slade Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net
noodles Posted August 9, 2002 Author Posted August 9, 2002 Thanks, that should help out. 12 and 10 huh, thanks You wouldn't know the answer to my second question would you. I would like to know an approximate wind velocity over the engine cowl when the plane is idling. I know that your plane isn't flyng yet, but figured someone else might now. Quote Cozy IV project. Redheaded Stepchild of The Canard Community
John Slade Posted August 9, 2002 Posted August 9, 2002 Sorry, but I have no data on windmilling prop air speeds. Standing behind a Cessna 172 with the engine running, I might guess at 30mph. Quote I can be reached on the "other" forum http://canardaviationforum.dmt.net
