Jon Matcho Posted June 6, 2004 Share Posted June 6, 2004 I found the firewall plywood I received from Wicks not to be what I expected -- aircraft-grade flat. Instead, it's warped into an odd concave shape (see attached). When sitting on one side, two far corners lift by 3/4". When flipped on the other side, the shorter edges lift in the middle by 1/8". I am thinking that when I cut the plywood longways it will relieve some of this tension. Also, it doesn't take much weight at all to push the piece down flat when on the one side. That being the case, I am thinking to leave it as-is, glass, and let cure with some weight on the top. Thoughts? Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Jerry Schneider Posted June 6, 2004 Share Posted June 6, 2004 I would give Wicks a call. Betchya they replace it. Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
Jon Matcho Posted June 7, 2004 Author Share Posted June 7, 2004 Betchya they replace it.I should have taken that bet. I was passed to "Don the Wood Guy" who explained to me, "plywood will warp if there is any humidity around -- it's a fact of life with plywood." Knowing that it has been raining on and off for the past few weeks, I couldn't argue with that. It's also a relatively small warp, so I'm not worried about being able to get it to cure flat. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Jerry Schneider Posted June 7, 2004 Share Posted June 7, 2004 I live in Florida. It's a state where 9 months out of the year you need a snorkle to walk the dog. I've never had a piece of firewall board warp on me. I have some still in my workshop unglassed. I'll check it tonight for warpage. My suggestion: If you can't get it to cure reasonably straight, send it back for replacement. You paid top dollar for that stuff, and it's not your fault if they let it get wet. Also, if you keep it, glass it on the convex side. That way, you can weight it for flat cure. Now that I think of it, I may have had to do that very thing. But, my my warpage was minimal, if at all. But of course, I could be wrong. Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
Jon Matcho Posted June 7, 2004 Author Share Posted June 7, 2004 You paid top dollar for that stuff...Over $37 for a 2' x 4' sheet. I rationalized that into $0.03 per square inch -- cheap! Thanks Jerry, I'll do just that -- concave side down and glass the convex side with weights. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Wayne Hicks Posted June 8, 2004 Share Posted June 8, 2004 Return the plywood and ask for replacement! One ply BID on both sides will not be enough to unwarp the plywood. Like others have said, you pay top dollar for flat plywood. Get your moeny's worth. Send it back. Quote Wayne Hicks Cozy IV Plans #678 http://www.ez.org/pages/waynehicks Link to comment Share on other sites More sharing options...
Jim Kaiser Posted June 8, 2004 Share Posted June 8, 2004 I talked with Jon Matcho about the warp and he is going to try and press it flat with a little water and weight. If that does not work Wicks will replace the plywood. GM W/A Quote Link to comment Share on other sites More sharing options...
macleodm3 Posted November 17, 2006 Share Posted November 17, 2006 Jon, What ever happened with this plywood situation? I opened my shipment up from Wicks yesterday and my plywood looked like your plywood! (warped) Did you send yours back? (if so, they sent it to me) Quote Andrew Anunson I work underground and I play in the sky... no problem Link to comment Share on other sites More sharing options...
Jon Matcho Posted November 17, 2006 Author Share Posted November 17, 2006 I did what Wicks advised: Apply a small amount of warm water to both sides Weight down on a FLAT surface Allow to dry for a couple of days The warpage essentially went away after that. I haven't actually glassed the permanent firewall yet as I've been waiting to verify the setup of my modified/widened firewall. I plan on doing it this weekend and will re-check the plywood. In hindsight, unless it's "violently" warped, I really don't think it's a big deal to have a small amount of warp. Clamp, flox, and tape (or whatever the firewall mounting procedure is), and it will be fine. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
macleodm3 Posted November 17, 2006 Share Posted November 17, 2006 Roger that Jon, Thanks for the reply. It isn't bad warpage, and it I even managed to get another piece for free, it might show up the same way. This plywood piece does not look like its been wet, but its warped almost exactly the same as the piece you have. When I'm fininished, years from now with my plane flying crooked, I can blame it on that piece of warped plywood. I'll wait to here from you to see if your piece is now flat before proceeding. Thanks! Andy Quote Andrew Anunson I work underground and I play in the sky... no problem Link to comment Share on other sites More sharing options...
Jon Matcho Posted November 17, 2006 Author Share Posted November 17, 2006 When I'm fininished, years from now with my plane flying crooked, I can blame it on that piece of warped plywood. I've since learned that NONE of the following will make a crooked airplane: Mildly warped firewall plywood Bulkheads off by 1/4" Airfoil hotwire templates off by 1/4" Fuselage side jigs off Steve Volovsek told me, "There are so many opportunities to verify square, flat, and true." Some include: Fuselage assembly Main spar mounting Canard mounting Main wings mounting The last of my worries with all of this is whether anything in the first list happened. The second list is where you need to take care to be "exact". Do that (build according to plans) and you'll be straight and true. I'll wait to here from you to see if your piece is now flat before proceeding. Thanks! AndyGreat! I appreciate the challenge to get my firewall done. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Jon Matcho Posted November 20, 2006 Author Share Posted November 20, 2006 I plan on doing it this weekend and will re-check the plywood. I'll wait to here from you to see if your piece is now flat before proceeding.I didn't get to building the firewall this weekend -- mounting my landing gear did happen though -- but I did verify the plywood is still flat. It has been sitting horizontal for over 2 years , so I'm sure that helps (storing it the way it's supposed to be). Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
macleodm3 Posted November 21, 2006 Share Posted November 21, 2006 Mine did not flatten out over the weekend. I'm getting a new piece from Wicks. We'll see if its any better than the first one. Thanks for you help! Andy Quote Andrew Anunson I work underground and I play in the sky... no problem Link to comment Share on other sites More sharing options...
Jon Matcho Posted November 21, 2006 Author Share Posted November 21, 2006 Yeah, I saw your posts. I happened to let mine stay flat for more than a weekend though, not entirely on purpose. Also keep in mind that you don't *need* to make the permanent firewall until Chapter 6. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
