left / right fuel tank selector handle
  • Please log in to reply
2 replies to this topic
#1 paulgsmart
paulgsmart
    New Member
  • Members
  • Pip
  • 2 posts
  • Paul Smart
  • Northern New South Wales Australia
Posted 02 January 2018 - 07:48 PM
Hi
I am having trouble inflight reaching the L/R fuel tank selector handle located in the usual place between the pilots legs.
Unfortunately, I am 173 cm in height, sit in a raised position, my arms are too short, I can only just reach the handle with the tips of my fingers and my head is hitting the canopy during the tank change, it sometimes takes me a couple of shots to complete the change. All in all an unpleasant experience.
Does anyone know where I can buy an extended L / R fuel tank selector handle that I can reach more easily ?
Are there any other simple solutions to my problem?
Cheers
Paul G Smart
#2 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 793 posts
  • Kent Ashton
  • Concord, NC
Posted 02 January 2018 - 09:01 PM
I presume you have the usual cheap Weatherhead valve.
http://www.aircrafts...pages/whfsv.php
You could try extending the handle. Tilt the plane back so the valve is above the fuel level. Remove the stem and handle. Fit an extension tube over the stem and rivet it to the stem. Rivet a rod in the top of the new tube. drill and tap it for the screw and shape the flat spot for the handle.
I did this on a new build in order to raise the handle. Any other solution is quite a bit more work, I think.
That would be a good time to lube the spool with a thin smear of Fuel Lube. Don’t use much or bits of it will lodge in ghe gascolator screen and stay there.
Alternatively, maybe there is a short tool you could make to reach the handle.
#3 Andrew Anunson
Andrew Anunson
    Chapter 21
  • Verified Members
  • 383 posts
  • Andrew Anunson
  • Wise, VA
Posted 04 January 2018 - 09:14 AM
"173 cm in height"     5'8".... not typically a problem.
"sit in a raised position"   I am guessing you are using a thick seatback cushion?
"my arms are too short"  like a T-rex?  Are they normal length arms or do you have an unusual circumstance?
"I can only just reach the handle with the tips of my fingers and my head is hitting the canopy during the tank change"  THIS sounds very unsafe.  This does not sound typical for a Long-EZ.
"Does anyone know where I can buy an extended L / R fuel tank selector handle that I can reach more easily ?"  There are many good fuel valve solutions.  This may involve moving your valve, installing a different valve, or some other solution.
You DO have a fixable problem here, and it does need to be addressed.
Please post some photos (from different viewing perspectives) of you fuel valve installation to help everyone understand the problem and therefore recommend a solution.
Edited by Andrew Anunson, 04 January 2018 - 09:16 AM.
Andrew Anunson
Stats
