Cozy IV - project - Transportation help
cozy transport project
  • Please log in to reply
26 replies to this topic
#21 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 795 posts
  • Kent Ashton
  • Concord, NC
Posted 31 December 2017 - 10:34 AM
maybe an AnP inspection on the engine, and if its good as is, I might just try to get the Cozy flying with this, use up the remaining 400-500 hours (which should be a good few years), and then invest in an IO-360 :)]
I just grin every time I think of the project and I wonder if I am getting ahead of myself...  :rolleyes:
Yep, you could certainly go that direction but A&Ps don't work for free and if you find rust or valve problems, you're back to putting a lot of time and money into a less-than-ideal engine and a prop for it.  If you had a logbook, you'd know a lot more.  For example, a flight-school motor that flew every day for 1500 hours is a much better candidate than the engine off an airplane that flew 50 hours a year for 30 years.
If you determine you want to use it, there are cheap ways to inspect it yourself.   Rust, cylinder wall condition, valve wobble, and spalled cams are things to look at.
http://www.vansairfo...=vividia valves
http://forum.canarda...31&postcount=40
http://forum.canarda...32&postcount=41
If those are OK, just bolt it up and use it.
OTOH, you don't need to get married to this engine just because it came with the project.  Even with no engine logs, if you can reasonably assure a buyer you've inspected for those things, this engine would sell pretty easily, I would guess, then you can get the bigger engine.
#22 Cozy846
Cozy846
    Composite construction Newbie
  • Verified Members
  • 23 posts
  • Peter Swayze
  • Battle Ground WA
Posted 01 January 2018 - 07:07 PM
Andrew & Kent
Thanks Guys, all this information has explained a great deal. I wasn't working in an Engine shop and we worked with what we had.
I am sure there are certain engine types that are the best selections in these class of engines. Maybe a thread else where.
Best regards.
#23 montun23
montun23
    Member
  • Members
  • PipPip
  • 14 posts
  • Manju Nag
  • Olathe
Posted 02 May 2018 - 07:02 PM
All,
wanted to provide an update on this, I was able to move the COZY from DEtroit to Kansas over the last weekend. Used a 20 ft trailer, 82 inches wide. got wide load permits for all states, well, cops never stopped me anyplace, the drive was ok, wansnt too bad, a few construction zones were a little tricky. reached Kansas last night, no issues with the move, no damages.... Had wrapped the plane in moving blanket and shrink wrapped it... the shrink wrap was maybe not rqequired, but was hard to keep the moving blankets on.. had to use a LOT of duct tape (no taping anywhere on the surface of the cozy), and a lot of shrink wrap (but took about 30 minutes to unpack).
Wanted to share this for those who might want to move a cozy again. below are the pictures and some details of what I did,
- COZY loaded with the nose in the front
main gear legs on the trailer axle (the bulk of the weight is still in the front of the trailer axle)
wiings laid next to each other with minor overlap of the trailing edhes (moving blanket and foam in between to prevent damage)
wooden studs screwed to the trailer floor and padded to stop the wings or other parts from moving
three 2 inch wooden blocks screwed one above the other used as "chocks" to prevent the cozy from moving back and forth
foam pads under the nose
ratchet tie downs in the spar holes to prevent aircraft rolling
tie down along the top of the gear legs to prevent cozy from buckling foprward for any hard braking
took us 13 hours to load the trailer and abot 3 hours to unpack...
feel free to ask questions if you have any
https://photos.app.g...mCxk0c4Fa111ZI2
#24 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 795 posts
  • Kent Ashton
  • Concord, NC
Posted 02 May 2018 - 08:13 PM
Congrats!
It looks like you might be able to get the wings on in your garage.
#25 montun23
montun23
    Member
  • Members
  • PipPip
  • 14 posts
  • Manju Nag
  • Olathe
Posted 03 May 2018 - 08:05 AM
Congrats!
Thanks Kent, yeah maybe one at a time :P
There is a support pole right in the middle of the garage, which would maybe be RIGHT where the wing tanks are....
#26 Jon Matcho
Jon Matcho
    Canard Zone Developer
  • Verified Members
  • 2,453 posts
  • Jon Matcho
  • Martinsville, NJ
Posted 08 May 2018 - 05:24 AM
Looks and sounds like a successful move. You have a lot of work remaining, but this is a great jump.
I feel like that often. I think it takes completing and flying to have that feeling go away, I hope.  :)
#27 Don
Don
    New Member
  • Members
  • Pip
  • 5 posts
  • Don Berlin
  • Tucson, Az
Posted 13 May 2018 - 05:16 PM
All fits on a 16 ft trailer
Also tagged with one or more of these keywords: cozy, transport, project
Stats
