Cozy IV - project - Transportation help
cozy transport project
  • Please log in to reply
21 replies to this topic
#1 montun23
montun23
    New Member
  • Members
  • Pip
  • 8 posts
  • Manju Nag
  • Olathe
Posted 25 December 2017 - 10:01 AM
Hello Folks,
new to this community and am very excited to take on a Cozy IV project. The project has a complete airframe, engine installed, missing electrical and avionics and all the cosmetics. The project is located in Detroit and I am in Kansas. ANY IDEAS on how to move it? with the wings removed, I believe the width sits around 12 feet with the strakes tip to tip.
Also, any estimates on a performance with an O-320? this is what the project currently has installed, might consider switching to an O-360.
Any and all help is truly appreciated :)
Regards
Manju
#2 Cozy846
Cozy846
    Composite construction Newbie
  • Verified Members
  • 23 posts
  • Peter Swayze
  • Battle Ground WA
Posted 26 December 2017 - 12:49 AM
Get measurements.
I've seen the Cozy Mk IV hauled on a low deck flat bed on an angle.
You will need a very low deck trailer. Know your Height when loaded.
Check every overpass and the one you fail to read may make you CRY.
This to allow it to fit with in width and height limits on the road ways.
My dad used foam and straps to secure the Aircraft He hauled.
Twist the straps over so they are not flat and allow them to vibrate.
When you go down the road and hear them you'll figure this out.
Most Flat bed Drivers twist there straps and the Rookies can be spotted
when they fail to twist them.  You load will be in the wind so you
need to think how this will effect your new AC. Nothing can rub
and wear so you need to recheck your load 10 miles after you get going
then 50 miles and every time you stop get out and check every thing.
Invest in good straps. I mean ratchet straps. Ropes are ok if you haul
stuff every day and can use a good slip knot. Support every edge with
piece of carpet, rag or something to help. I've wrapped tape on the
rope to prevent damage. Use good but useful carpet end cuts and
these can be screwed to the deck and used to brace when applied right.
You might be able to use an old mattress to protect your wing.
Look around and call Mattress Stores if you can barrow there used junk.
You may need to build a brace to keep wind damage from attacking the
rudders.  So take your Black N Decker tools and supplies to make it work.
Bring tape. light bubs and hand tools 2x4's at the local hardware store too.
Wire connection to the trailer always fail with the ground. A wire brush and
a 177-22 caliber bore brush helps to keep the fuzz happy.
Avoid Rest Stops. Too many bad stories.
How to load the Fuselage and hold it at an angle... I have yet had to do this to a Canard.
The other AC were salvage and we did it by shear Man power and Come a Longs..
Check a few Builders logs and check with them on there trip from Garage to Hanger.
Don't go alone and Never Ever do Business with Cash. EVER. Not past a few hundred,
Trust what you can verify. Hope you know what your buying. Buyer Beware.
Edited by Cozy846, 26 December 2017 - 01:00 AM.
#3 Cozy846
Cozy846
  • Verified Members
  • 23 posts
  • Peter Swayze
  • Battle Ground WA
Posted 26 December 2017 - 01:20 AM
TheRethink.
Get measurements.
when they fail to twist them. Your load will be in the wind so you
On the O-320,,,,,, I would look at the IO-360 series Lycoming's if I was going to use this type Engine,
Also  I've read about the heat and cooling issues builders fight with these Air cooled engines. Some one has to have perfected this by now. Down draft / Up draft / Split draft mix who knows. Air cooled is not my option so your on your own. Research this so you might get it right for your AC.
I'd rethink the baffling design. Every one starts with the Tractor design from the Conventional use of these power plants..... Maybe the baffling needs to be rethought because the Air flow is not flowing into the nose but exiting there...... Directional baffling to individualize the cooling to each Jug?  Thus one could install butterfly valves to limit or open cooling air flow?  Jug jackets and Air flow Manifold?.  Don't attack this. It was a 2 minute thought. So the punch line wasn't written.  Good Luck.
#4 Andrew Anunson
Andrew Anunson
    Chapter 21
  • Verified Members
  • 375 posts
  • Andrew Anunson
  • Wise, VA
Posted 27 December 2017 - 10:28 AM
\ANY IDEAS on how to move it? with the wings removed, I believe the width sits around 12 feet with the strakes tip to tip.
Here is a photo of Zubair moving his Cozy project across the USA...
http://forum.canarda...10&d=1330640503
Note that he used a very heavy duty trailer (Not a harbor freight trailer).
He also used a moving van for the wings, canard.... all the extras.
There are many online stories of moving a Cozy... its all been done, just do some searching and you can find it.
Edited by Andrew Anunson, 27 December 2017 - 10:29 AM.
Andrew Anunson
#5 Andrew Anunson
Andrew Anunson
    Chapter 21
  • Verified Members
  • 375 posts
  • Andrew Anunson
  • Wise, VA
Posted 27 December 2017 - 10:42 AM
Also  I've read about the heat and cooling issues builders fight with these Air cooled engines...
I'd rethink the baffling design...
Congratulations on your purchase!!!  Can you share a bunch of photos with us?
The O-320 (150HP or 160 HP) seems to be a little small for for the MKIV.  It can work, but most highly recommend the 360  (180HP).
The Cozy MKIV plans have us install the O-360... the IO-360 will give you an additional 20HP over the O-360 (very nice) but it is quite a bit heavier and some plans parts (engine cowls and baffles) won't fit.  I would go with the plans O-360 and do the very simple upgrade to FI if you want.
When builders follow the plans, they typically have good cooling.  I am currently building the plans engine baffling for the O-360 with FI, and these baffles are easy to build and almost all the MKIV's that fly a lot use the plans cooling.  Its a good system.
Andrew Anunson
#6 montun23
montun23
    New Member
  • Members
  • Pip
  • 8 posts
  • Manju Nag
  • Olathe
Posted 28 December 2017 - 01:19 PM
Hello all,
Thanks for all your inputs. Been talking to a few folks and been looking up the "oversized" load regulations. looks like I should be able to haul it on a flat bed as long as it under 12 feet tip to tip without too much paper work or without pilot vehicles. Will make sure that the strakes are at over 6 ft ground up for safety purposes. Will be passing thru Michigan, Indiana, Illinois, MO and KS.
As for the engine, very inclined to swap it to an O-360.
Is there a cozy builders/owners list? I am looking for somebody in the detroit area who could potentially assist with a pre-buy inspection. will put up a link with the pics soon...!!
Appreciate all the input folks.
Thanks
#7 Barry
Barry
    Member
  • Members
  • PipPipPip
  • 47 posts
  • BarryShelton
  • Huntersville, NC
Posted 28 December 2017 - 09:49 PM
https://groups.googl...m/cozy_builders
http://www.cozybuilders.org/
Edited by Barry, 28 December 2017 - 09:50 PM.
#8 Cozy846
Cozy846
  • Verified Members
  • 23 posts
  • Peter Swayze
  • Battle Ground WA
Posted 29 December 2017 - 05:27 AM
"The Cozy MKIV plans have us install the O-360... the IO-360 will give you an additional 20HP over the O-360 (very nice) but it is quite a bit heavier and some plans parts (engine cowls and baffles) won't fit.  I would go with the plans O-360 and do the very simple upgrade to FI if you want."
According to Lycoming
O-360 C4P weight is 275 to the heavier O-360 G1A6 weight at 303 pounds. For 180 hp depends on your power plant you choose.
IO-360 L2A weight is 278 to the heavier IO-360 J1AD weight at 323 pounds Dry
So for the weight I trade up. And we form our cowling around the power plant.
As far as the Heat issues I have read where some have had hot cylinder issues. That could be from
a number of issues. One is dealing with very old tech here and no one will stick there neck out very far with the punitive legal fees Aviation companies face with product liability insurance. Pay 10 times what it is worth for 1/2 the life span.
But not my problem I quit working on these Jurassic era designs well over  20 years ago.
https://www.lycoming...al 60297-12.pdf
#9 Andrew Anunson
Andrew Anunson
    Chapter 21
  • Verified Members
  • 375 posts
  • Andrew Anunson
  • Wise, VA
Posted 29 December 2017 - 10:17 AM
Ok... we are sorry for the thread drift here... :)
We should be using the terms "parallel valve"  (lightweight 360, typically 180hp)  and "angle valve" (heavyweight 360, typically 200 hp).
The lightweight IO-360 you listed (the L2A) is rated at only 160HP.  The lightweight IO-360's are typically parallel valve engines and they are typically rated at 180 hp.
If you want the additional 20HP, you need to look at the heavier (20 to 40 lbs) angle valve engines.
Most builders do not build their own engine cowlings... its cheaper and much easier to buy one from Featherlite.
Most EZ's and Cozy's that actually go places and fly a lot have airplane engines.
  • Cozy846 likes this
Andrew Anunson
#10 Andrew Anunson
Andrew Anunson
    Chapter 21
  • Verified Members
  • 375 posts
  • Andrew Anunson
  • Wise, VA
Posted 29 December 2017 - 10:30 AM
Yes... you should join the Cozy builders email list (its a Google Group ----  search for Cozy Builders on google groups).  Builders and fliers monitor that list.  If you join the list, you can have access to a map showing all the builders in the US.
There are builders in the Detroit area that can most likely look at the project for you...
Right now there are 4 places to go for Cozy information....
This Forum
The Other Forum
The Cozy Builders Email List (Google Group)
The Canard-Aviators Email List (Yahoo Group)
It may seem silly  to have to check 4 places for information... but it is what it is.
If you post the request to the two email lists you should get some good responses.
Andrew Anunson
#11 montun23
montun23
    New Member
  • Members
  • Pip
  • 8 posts
  • Manju Nag
  • Olathe
Posted 29 December 2017 - 02:17 PM
The project I am looking at has an O320 E2D "wide deck" with an "A" in the serial number. I have seen posts where you could upgrade to 160 hp using high compression pistons. I am assuming there is no way to get that to 180 HP. has anybody got such  a conversion? is it worth it at all? or instead just swap the engine out to an O 360?
#12 Andrew Anunson
Andrew Anunson
    Chapter 21
  • Verified Members
  • 375 posts
  • Andrew Anunson
  • Wise, VA
Posted 29 December 2017 - 05:09 PM
There is an engine by Titan that they call the stroker 340... I dont know much about it, but they advertise it as a 320 thats been increased to 340 ci and its rated at 180hp. Possible, yes. Your best option? That depends on a lot of things including money.
If your 320 engine has been sitting for a year or more it may have enough rust inside to warrant a rebuild. Go ahead and convert it to a 340... you'd have a lightweight 180 hp option.
The options are almost limitless...
Andrew Anunson
#13 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 691 posts
  • Kent Ashton
  • Concord, NC
Posted 29 December 2017 - 05:11 PM
What is the time and history on your O-320?  A  low time engine with a documented professional overhaul would sell rather easily, I'm guessing.  If it's over 1000 hours then it's probably not worth the time and money trying to increase the HP but someone would buy it for the time remaining.  Then take that money and buy an overhauled O-360 or watch the salvage yards and ads for a good deal on an O-360.  There is a lot to know about using and buying engines.  Google John Deakin, Mike Busch Avweb, and "Sky Ranch Engine Manual".  They have written a lot about them over the years.  Good stuff.
#14 montun23
montun23
    New Member
  • Members
  • Pip
  • 8 posts
  • Manju Nag
  • Olathe
Posted 29 December 2017 - 05:47 PM
Kent, it has 1500 hours, pickled for the last 8 years or so. as of now, most likely it has no logs. seller isint sure if its there or not at this time.
#15 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 691 posts
  • Kent Ashton
  • Concord, NC
Posted 29 December 2017 - 06:42 PM
I think most engine buyers would say that with no history, no logs and that much time it is pretty much a “core” engine. IMO, It’d be foolish to spend a lot of time and money on it, since it isn’t the best engine for the project. You might trade it to a reputable engine shop for credit towards what you need, or if you find the logs, sell it for a bit more.
Even if you find the logbooks, you could spend a lot of hours trying to use it as is and find that in a few hours it is using oil or making metal. Now you really have a “core” engine that you wasted a lot of time on.
Edited by Kent Ashton, 29 December 2017 - 06:44 PM.
#16 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 691 posts
  • Kent Ashton
  • Concord, NC
Posted 30 December 2017 - 06:17 AM
Just thinking . . . Nothing says you have to buy this project with a mystery-engine. Make a fair offer for the rest of the project and let the seller deal with it.
People are always looking to unload their problems. You’re buying his problem
#17 Andrew Anunson
Andrew Anunson
    Chapter 21
  • Verified Members
  • 375 posts
  • Andrew Anunson
  • Wise, VA
Posted 30 December 2017 - 10:37 AM
Thats a good idea Kent... its not the correct engine for the MKIV, history unknown. What would that 320 be worth? $2000? $2500?
Also... do get your pre-buy. We've all seen some really poor workmanship here and there (not that its normal)... you want to start with one of the best projects, not one of the worst.
Do you have pictures you can share here? Price?
Are you getting signed up for the email list yet?
Andrew Anunson
#18 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 691 posts
  • Kent Ashton
  • Concord, NC
Posted 30 December 2017 - 02:08 PM
I see that there are no O-320s listed on Trade-a-plane and Wentworth has none for sale at the moment so maybe it's not so easy to find a rebuildable core.  Here is one on ebay with logs for $7K.  I would guess a core is worth at least $4K, even if runout and no logs.
https://www.ebay.com...PxaGaxn&vxp=mtr
If you go into the "advanced search" feature on ebay, you can see what engines sold, or did not sell for.  The pawn shops camp on that page.  That's how they know how much to loan on what you pawn.  :-)
Here are some pics Manju sent me.  I don't think he'll mind if I link to them.  Let's do a pre-buy right here!
https://photos.googl...F8xT2hfMi1oVmZn
#19 montun23
montun23
    New Member
  • Members
  • Pip
  • 8 posts
  • Manju Nag
  • Olathe
Posted 31 December 2017 - 08:03 AM
Detroit EAA chapter is assisting with the pre-buy. in touch with some real nice folks out there. Should be back up there mid Jan.
Put in a request with Marc to get me added to the mailing list.. should be on there soon
#20 montun23
montun23
    New Member
  • Members
  • Pip
  • 8 posts
  • Manju Nag
  • Olathe
Posted 31 December 2017 - 08:09 AM
Kent, your estimates I think are pretty accurate. I dont see too many E2Ds for sale, but generally in reading other groups and forums, I believe the E2Ds are one of those "bullet proof" engines :) Seen that term used a lot.
Havent really decided yet...  maybe an AnP inspection on the engine, and if its good as is, I might just try to get the Cozy flying with this, use up the remaining 400-500 hours (which should be a good few years), and then invest in an IO-360 :)]
I just grin every time I think of the project and I wonder if I am getting ahead of myself...  :rolleyes:
Also tagged with one or more of these keywords: cozy, transport, project
Stats
