Engine Cozy mk3
Engine cocymk3
  • Please log in to reply
3 replies to this topic
#1 Kimjensen
Kimjensen
    Member
  • Members
  • PipPip
  • 11 posts
  • Kim jensen
  • Aalborg Denmark
Posted 14 September 2017 - 02:38 PM
Hello again
Eny One Who Can give a feedback regarding engines.
I have possibiliti to get a O-320 or a IO-360 for my cozy3
Positive / negative Comments?
#2 Kent Ashton
Kent Ashton
    Member
  • Verified Members
  • 713 posts
  • Kent Ashton
  • Concord, NC
Posted 14 September 2017 - 05:31 PM
I owned a C-III with an O-320 for a while.  It was a good engine and HP for the airplane.  IMO, an IO-360 is too much engine for the design.
- A heavier engine and prop is going to require more ballast in the nose when flying solo.  I used 40-50 lbs of shot in my C-III/O-320 when solo.  You'd probably need more with an IO-360.  Aside from the problem of shuttling bags of ballast around, It offsets some of the advantage of the extra HP.
- Ground handling would be trickier.  It would be easier to tip-back.
- The engine mounts (essentially Long-EZ mounts) were designed for an O-235 unless they have been beefed up.  Even if they have, it's a lot of leverage on them with the heavier engine and HP hanging on angles that are about 10-12" apart, vertically.  The C-IV has better mounts, IMO.
- The landing gear (Long-ez gear) is not as strong as the Cozy IV.    Yes, people have put O-360s on the EZs but heavy EZs have problems with the attach angles getting loose.  Some have problems with the strut sagging.  The C-IV has a bigger, stronger MLG strut.
- The bigger engine is useful for takeoff and climb but your cruise will not be that much faster.  You'll get there a few minutes quicker but . . .
- Your range might be less because you burn more GPH.
Edited by Kent Ashton, 14 September 2017 - 05:32 PM.
#3 Voidhawk9
Voidhawk9
    44°24'0"S, 171°15'0"E
  • Verified Members
  • 54 posts
  • Cameron Garner
  • Timaru, New Zealand
Posted 14 September 2017 - 08:47 PM
An O-320 and a lightweight constant speed propeller would sure make it perform!  :cool1:
Aerocanard (modified) SN:ACPB-0226 (Chapter 6)
Canardspeed.com (my build log and more)
X-plane (Flight simulator) Flight Model Master: X-Aerodynamics
(GMT+12)
#4 Kimjensen
Kimjensen
    Member
  • Members
  • PipPip
  • 11 posts
  • Kim jensen
  • Aalborg Denmark
Posted 15 September 2017 - 01:49 PM
Thank you I Will go for the 320
Stats
