Toe brakes
  • Please log in to reply
7 replies to this topic
#1 B52
B52
    Member
  • Members
  • PipPip
  • 21 posts
  • Jacob
  • Australia
Posted 22 August 2017 - 01:00 AM
Most probably mentioned somewhere.
Do the rudder pedals in Cozy / EZ have toe brakes ? Looks like the master cylinders are fixed to the pedals and not independent to the rudder, in other words at all times they simply activate together with the rudder movements, is this correct ?
Edited by B52, 22 August 2017 - 01:06 AM.
#2 TMann
TMann
    Got Foam?
  • Verified Members
  • 1,757 posts
  • Thomas Mann
  • Omaha, NE
Posted 22 August 2017 - 08:11 AM
There is an amount of travel that the rudder pedal executes beyond which the master cylinder is engaged.
#3 Andrew Anunson
Andrew Anunson
    Chapter 21
  • Verified Members
  • 384 posts
  • Andrew Anunson
  • Wise, VA
Posted 22 August 2017 - 03:18 PM
No, they do not have toe brakes.
The first half of rudder pedal movement is rudders, then after the rudders are fully deployed the wheel brakes start to actuate.
I haven't operated this system yet, but most canard pilots say that it works fine.
Andrew Anunson
#4 TMann
TMann
    Got Foam?
  • Verified Members
  • 1,757 posts
  • Thomas Mann
  • Omaha, NE
Posted 22 August 2017 - 03:58 PM
If you look at the attached drawing the blue area depicts a rod that is threaded into which the master cylinder rod threads into.
The blue section guides the master cylinder rod into the tube and keeps everything aligned.
Once the outside tube hits the adjustable stop nut, the master cylinder is engaged.
#5 B52
B52
    Member
  • Members
  • PipPip
  • 21 posts
  • Jacob
  • Australia
Posted 23 August 2017 - 07:12 AM
I can see the simple design, only 2 master cylinders for both sets of rudder pedals.
In conventional aircraft when applying foot pressure to the right pedal the left pedal will move towards you. In the cozy does the left pedal remain static when applying pressure to the right pedal ?
#6 TMann
TMann
    Got Foam?
  • Verified Members
  • 1,757 posts
  • Thomas Mann
  • Omaha, NE
Posted 23 August 2017 - 08:58 AM
On all of the Rutan based designs, the rudders move independent of each other and only travel outward.
You can deploy both rudders at the same time to create additional drag as you approach the runway.
#7 B52
B52
    Member
  • Members
  • PipPip
  • 21 posts
  • Jacob
  • Australia
Posted 28 August 2017 - 12:35 AM
What is the function of the square tubes on the pedals ?
#8 Andrew Anunson
Andrew Anunson
    Chapter 21
  • Verified Members
  • 384 posts
  • Andrew Anunson
  • Wise, VA
Posted 28 August 2017 - 08:03 AM
The square tube has holes in it for adjustment.
Also, we need to use a 2.5:1 leverage ratio for mounting the master cylinder to the rudder pedal, and the attached image is closer to a 1:1 ratio so its wrong.  But the image should answer your question.
Edited by Andrew Anunson, 28 August 2017 - 08:07 AM.
  • Jon Matcho likes this
Andrew Anunson
Stats
