Sammac91 Posted June 19, 2017 Share Posted June 19, 2017 What do builders normally do with the bulkhead cutouts, do they leave the exposed foam or put something like food in the channel for durability? Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted June 19, 2017 Share Posted June 19, 2017 You definitely don't want to put "food" in there! Do you mean the inner edge of the bulkheads where the holes are cut? Most leave the foam exposed in anticipation of bonding to something else. However, in cases where that will not be true (leg holes), you could put a small amount of micro in there to keep the edges smooth (possibly to find out months later that you'll want to widen this area by 1/4" on each side ). I'd wait until finishing and until you are certain it's worth doing, otherwise you're adding weight where it may not even be visible. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Sammac91 Posted June 19, 2017 Author Share Posted June 19, 2017 Hi Jon, It's the leg cutout I was thinking about. Just seems it's a high traffic area with the chance of being chipped out over time plus the foam is just exposed there. Nothing is mentioned in the plans and I guess paint somewhat fills and seals off the foam. Cheers, Sam Quote Link to comment Share on other sites More sharing options...
macleodm3 Posted June 19, 2017 Share Posted June 19, 2017 Like Jon said, you can just the leave leg cutouts as is. If its going to be exposed to weather (like the fuselage sides at the canard cutout) then its good to seal it. Keep it light and simple (to help assure you get it flying someday and so that it flies light and fast). 1 Quote Andrew Anunson I work underground and I play in the sky... no problem Link to comment Share on other sites More sharing options...
Jon Matcho Posted June 19, 2017 Share Posted June 19, 2017 It's the leg cutout I was thinking about. Just seems it's a high traffic area with the chance of being chipped out over time plus the foam is just exposed there. For reasons I share with Andrew (weight and being drawn into the weeds of perfection), I suggest not doing anything until you realize you're certain that you know the best time to address. With that said, I plan on digging a shallow cavity in the leg holes and filing with micro for the "high traffic" reason you identified (and it will look better). I won't do it now because I just may increase the width and/or height of the area slightly when it's time for avionics, etc. The more material I have to work with, the better. 1 Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
SteveJ Posted March 22, 2019 Share Posted March 22, 2019 Not mentioned... My experience/policy dealing with foam and fiberglass construction is that before paint, at the latest, ALL foam MUST be sealed. Too many primers/paints out there that eat too many foams otherwise. Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted March 25, 2019 Share Posted March 25, 2019 On 3/22/2019 at 7:21 PM, SteveJ said: Not mentioned... My experience/policy dealing with foam and fiberglass construction is that before paint, at the latest, ALL foam MUST be sealed. Too many primers/paints out there that eat too many foams otherwise. There's nowhere that you should see exposed foam. It would be temporary if you did while waiting for a part to be assembled later. Most often you have foam + a micro slurry + at least 2 layers of fiberglass + more micro and then paint. The foam is well protected. With that said, and back to the original 'bulkheads' topic, I HAVE seen exposed foam on flying planes (albeit rough-finished) within the inside cutouts of bulkheads. A fix is to fill with 'micro'. You don't want to let fuel get near foam, which is another topic... Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
