SOLD: Wide Canopy - $200 obo
For Sale. A wide canopy, from Todd Parker I believe, custom sized for a wide Cozy (mine was going to be 45" wide.  $200 or best offer.
I had already cut the canopy bubble to size to my plane, but it should be adaptable to most other wider cozies. The rear is cut at a 15 degree
Here are some dimensions and pictures as I measured it on the box this weekend.
... Bear in mind of course, the material is very flexible until installed, so you can most likely cut, or trim edges to adapt it to any wider Cozy MkIV build, and possibly even to a stock 42" wide build.  (For example, if you squish the width, it will bulge higher and vice versa, or you can fix the height to your desired build and trim the bottom edges to match the necessary width.)
Length tip to rear cut line: 48"
Width: Approx 41-42"
Height: Approx 22"
** the extra "cut off" end is included, which you'll need to fabricate the rear turtleback windows.
***Note - this will need to ship via freight, unless you can pick up in Arlington VA, 22205
