lhendrick Posted November 17, 2009 Share Posted November 17, 2009 I have to take a pause in my building to move. I have removed the resin and hardener from the pump reservoirs, and I was wondering what to use to pump through the pump to cleanse it? Do I have to take the pump apart to clean it properly? I did notice as I pumped the last of the fluids out that the handle is slow to return to top position and worry that the metering is affected. It is a Michaels Engineering pump with MGS 335. Thanks. Quote Larry Hendrick Canardiologist Cozy Mark IV Started 2/12/2009 - Now on Chap. 6 http://web.me.com/lhendrick/Cozy_MkIV/Welcome.html Link to comment Share on other sites More sharing options...
TMann Posted November 17, 2009 Share Posted November 17, 2009 Metering is not affected. I would flush it with acetone. White vinegar works well but the acetone does a better job and will evaporate faster. If in doubt, call Michaels. They are a very helpful bunch. (Note: If you look at the procedures for using the hand pumps, they recommend the process I outlined above between uses) Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
argoldman Posted November 17, 2009 Share Posted November 17, 2009 I have to take a pause in my building to move. I have removed the resin and hardener from the pump reservoirs, and I was wondering what to use to pump through the pump to cleanse it? Do I have to take the pump apart to clean it properly? I did notice as I pumped the last of the fluids out that the handle is slow to return to top position and worry that the metering is affected. It is a Michaels Engineering pump with MGS 335. Thanks. Check with others, but I think that I used denatured alcohol. (it's been a while). While you are at it, replace the reservoirs with new ones. So much easier to do when empty and non-sticky. If you call yourself the canardologist, can I be the proptologist?? Quote I Canardly contain myself! Rich Link to comment Share on other sites More sharing options...
lhendrick Posted November 17, 2009 Author Share Posted November 17, 2009 Thanks for the fast answers. I have some acetone so thats what I'll use. You can call yourself a proptologist as long as you use a rubber glove:cool2: Quote Larry Hendrick Canardiologist Cozy Mark IV Started 2/12/2009 - Now on Chap. 6 http://web.me.com/lhendrick/Cozy_MkIV/Welcome.html Link to comment Share on other sites More sharing options...
