Noob Pump Question
aviator_edb
Ok, so I'm trying out a new Michael Eng variable ratio epoxy pump. I'm using MGS 285 and slow hardener. It supposed to be 100:50 by volume and 100:40 by weight so I set the epoxy pump up for that volume ratio. (Actually, it came set for 2:1 but I double checked it.)
Here's my question. After priming the pump I went to test the ratio by weight. Using a fairly accurate scale I come to 100:43 by weight. I'm a little rich with the hardener. Do I need to get it closer to 100:43 or should I quit worrying and build some airplane parts?
Weeellll... MGS 285 product sheet says 100:40 +/- 2. I guess if you're at ease with your cardiologist saying "that's close enough..." ;)
PDF attached, it may not be the most current.
Rick
MGSEpoxy285.pdf
