Phil Kriley Posted September 4, 2009 Share Posted September 4, 2009 Another builder asked - on the mail list - for the specific Matco master cylinder model, and the reply was MC-4, but as luck woould have it, the are TWO MC-4 parts - MC-4 and MC-4 .625 Does it matter? Also - I've seen photos on builder's sites where they use the Matco lay-down cylinders and have what looks like a glass fluid reservoir - what part number is that? I can't find anything like that in the AS&S site. Thanks! Quote Phil Kriley Cozy #1460 Chapter 13 - nose Right wing done - working on right winglet. Link to comment Share on other sites More sharing options...
TMann Posted September 4, 2009 Share Posted September 4, 2009 Just order them from JD at www.InfinityAerospace.com He's familiar with our planes and will supply the support for any questions that come up. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Lynn Erickson Posted September 5, 2009 Share Posted September 5, 2009 Another builder asked - on the mail list - for the specific Matco master cylinder model, and the reply was MC-4, but as luck woould have it, the are TWO MC-4 parts - MC-4 and MC-4 .625 Does it matter? Also - I've seen photos on builder's sites where they use the Matco lay-down cylinders and have what looks like a glass fluid reservoir - what part number is that? I can't find anything like that in the AS&S site. Thanks! is this the one? some people have had the clear plastic one crack. I have been using them for 5 years with no problem http://www.aircraftspruce.com/catalog/lgpages/reservoirs.php Some of the master cylinder have different bore and stroke. Give Matco a call they will know which one goes on the cozy. I have the Matco triple brake with 1.5" pistons and I use the MC 4 with the longest stroke Quote Evolultion Eze RG -a two place side by side-200 Knots on 200 HP. A&P / pilot for over 30 years Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted September 5, 2009 Share Posted September 5, 2009 is this the one. some people have had the clear plastic one crack. I have been using them for 5 years with no problem http://www.aircraftspruce.com/catalog/lgpages/reservoirs.php Those are the one's I have. Since they're plastic and have a 1/8" NPT thread in the bottom, you have to be VERY careful not to tighten the fitting too much. You can split them easily if you do. 7 years on mine - no leaks or problems. It's VERY nice to be able to see the brake fluid level at a glance. Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
steve Posted September 5, 2009 Share Posted September 5, 2009 is this the one? some people have had the clear plastic one crack. I have been using them for 5 years with no problem http://www.aircraftspruce.com/catalog/lgpages/reservoirs.php Some of the master cylinder have different bore and stroke. Give Matco a call they will know which one goes on the cozy. I have the Matco triple brake with 1.5" pistons and I use the MC 4 with the longest stroke i have the matco 2 puck, what master cyl. do i want ? Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
Neverquit Posted September 13, 2009 Share Posted September 13, 2009 Same here. The clear one are quite robust. I hung mine high (as recommended) and makes it EZ to monitor on a routine inspection. Matco says you can get by with only one but I like the idea of redundancy with two. Quote Link to comment Share on other sites More sharing options...
