TMann Posted June 19, 2009 Share Posted June 19, 2009 Okay, I'm a long ways off from this phase. I'm wondering if I could use Rhino Liner for the interior areas forward of the instrument panel. I'm just looking for a solution that will handle the scuffing that your feet put out and would wipe down well. is this material compatable? Durable? I see that Herculiner is a DIY product where (I believe) Rhino Liner is only available from a pro outlet. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
steve Posted June 19, 2009 Share Posted June 19, 2009 heavy and bad to breath. rocks or pavers work good in the drive.. Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
TMann Posted June 19, 2009 Author Share Posted June 19, 2009 heavy and bad to breath. rocks or pavers work good in the drive..Okay .... I'll try to translate this into English.The "bad to breath" comment I would assume would relate to the fact that the material is polyurethane based and in the event of a fire, fumes/gas would be a concern. So I would assume that those who seal their zolatone with polyurethane would essentially be in the same boat? Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Richard Schubert Posted June 20, 2009 Share Posted June 20, 2009 Good luck on the english translation Berkut 13 used jeffco, see http://www.berkut13.com/berkut42.htm Quote "We choose to do these things not because they are easy, but because they are hard." JFK Link to comment Share on other sites More sharing options...
TMann Posted June 20, 2009 Author Share Posted June 20, 2009 dind, ding, ding, ding, ding ......... we have a winner. I though I was pretty familiar with James' site but I missed that one. That is a perfect solution! Thanks for pointing that out. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted June 20, 2009 Share Posted June 20, 2009 TMan, You need the Jefco to seal the floor, I believe it was Vance who pointed out to me that he cannot paint the underside of the nose due to brake fluid seeping through the floor, the foam and out the bottom skin. Auto body shops sell cleaners to remove stuff on the surface but when you have seepage and saturation you are pretty much scr........ T'ain't nuthin gonna stick to that no mo. Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
TMann Posted June 20, 2009 Author Share Posted June 20, 2009 TMan, You need the Jefco to seal the floor, I believe it was Vance who pointed out to me that he cannot paint the underside of the nose due to brake fluid seeping through the floor, the foam and out the bottom skin. That's good to know. Not to mention the hydraulic fluid for the main gear. I guess that would raise a little hell with the paint as well. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted June 20, 2009 Share Posted June 20, 2009 Yes, build a tub for the pump, when you do the blow down valve and then bleed the system again it is going to foam out the vent on the pump all over the place. Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
dirtdox Posted June 23, 2009 Share Posted June 23, 2009 My brother in law does spray in bed liners. He uses the Scorpion bed liner system. It can be color matched and sprayed on pretty thin to save weight. It is tough stuff and gives a good non-slip surface. They also have a fire retardant system they say is for aircraft interiors. http://www.scorpioncoatings.com/products.asp Quote Link to comment Share on other sites More sharing options...
