Project Garuda CAD Drawings
  • Please log in to reply
27 replies to this topic
#1 ColinB
ColinB
    Member
  • Members
  • PipPipPip
  • 92 posts
Posted 14 June 2009 - 10:45 AM
The basis for the CAD, will be to setup the datums for the waterlines and flight stations
with this done the next logical step is to start work on the firewalls and bulkheads enabling me to construct the fuselage around these points
here is the picture of the firewall, the vertical line is the CL and the horizontal lines are the various waterlines im using as references for engine mount holes ect
Posted Image
#2 Edge 513
Edge 513
    Cozy540xtra N513DP
  • Members
  • PipPipPip
  • 727 posts
  • Carmel Valley, CA
Posted 14 June 2009 - 12:24 PM
Sweet mother of mercy, you're on a roll.
Self confessed Wingnut.
Get up off that couch!!! =)
#3 ColinB
ColinB
    Member
  • Members
  • PipPipPip
  • 92 posts
Posted 14 June 2009 - 01:28 PM
a quick knock up of the spar exterior edges havent been radiused yet
Posted Image
#4 Super-eze
Super-eze
    Member
  • Members
  • PipPipPip
  • 126 posts
  • Keith
  • New York
Posted 14 June 2009 - 02:11 PM
OK, How do you post an image?
Keith.
#5 ColinB
ColinB
    Member
  • Members
  • PipPipPip
  • 92 posts
Posted 14 June 2009 - 02:15 PM
in the message box there is a little icon (little square box with what looks like a mountain picture) thats for insert image i host my images in photobucket and then insert the direct link into the box that comes up when you click insert image
#6 Super-eze
Super-eze
    Member
  • Members
  • PipPipPip
  • 126 posts
  • Keith
  • New York
Posted 14 June 2009 - 02:37 PM
Thanks for the help!:)
Keith.
#7 Super-eze
Super-eze
    Member
  • Members
  • PipPipPip
  • 126 posts
  • Keith
  • New York
Posted 14 June 2009 - 02:54 PM
Are you going with the standard width of the fuselage?
Keith.
#8 ColinB
ColinB
    Member
  • Members
  • PipPipPip
  • 92 posts
Posted 14 June 2009 - 02:56 PM
nosegear bulkhead added
Posted Image
#9 ColinB
ColinB
    Member
  • Members
  • PipPipPip
  • 92 posts
Posted 14 June 2009 - 02:58 PM
it will be close, the shape may be slightly different, good thing about CAD is its a damn sight easier to change the shape if im not happy with it
#10 Super-eze
Super-eze
    Member
  • Members
  • PipPipPip
  • 126 posts
  • Keith
  • New York
Posted 14 June 2009 - 03:00 PM
Posted Image
Keith.
#11 Super-eze
Super-eze
    Member
  • Members
  • PipPipPip
  • 126 posts
  • Keith
  • New York
Posted 14 June 2009 - 03:01 PM
Posted Image
Keith.
#12 Steven
Steven
    Member
  • Members
  • PipPip
  • 15 posts
  • Melbourne, Australia.
Posted 14 June 2009 - 05:45 PM
Which CAD program are you using?
Steve Taylor
Cozy Plans # 1583 (26 June, 2009)
#13 Marc Zeitlin
Marc Zeitlin
    Flying Cozy MKIV N83MZ
  • Verified Members
  • 1,011 posts
  • Marc J. Zeitlin
  • Tehachapi, CA 93561
Posted 15 June 2009 - 02:54 AM
The basis for the CAD, will be to setup the datums for the waterlines and flight stations...
If you're going to create a CAD model of an aircraft, please use a standard aircraft coordinate system so that anyone else using the models will have a consistent coordinate system.
The X-axis goes out the nose, the Y-axis goes out the right wing, and the Z-axis goes down. Standard right hand rule.
#14 ColinB
ColinB
    Member
  • Members
  • PipPipPip
  • 92 posts
Posted 15 June 2009 - 04:17 AM
I am using the Delcam Powershape and Powermill system
Dont worry too much i can add in a separate work plane if i release the cad files, you may well see workplanes pointing in funny angles depending on how iv drawn the part and the workplane i have active at the time of the screenshot so i wouldnt read too much into it
#15 ColinB
ColinB
    Member
  • Members
  • PipPipPip
  • 92 posts
Posted 15 June 2009 - 09:53 AM
More work on bulkheads
this is the nose bulkhead, i forgot my usb drive when i came to work today so ill add it into the assembly tonight
Posted Image
#16 Marc Zeitlin
Marc Zeitlin
  • Verified Members
  • 1,011 posts
  • Marc J. Zeitlin
Posted 15 June 2009 - 10:19 AM
Having supported CAD systems for 20 years and taught classes in their usage, I know what a workplane is. I'm not talking about the workplane coordinate system - I'm talking about the Global Coordinate System. Do you understand the difference?
#17 ColinB
ColinB
    Member
  • Members
  • PipPipPip
  • 92 posts
Posted 15 June 2009 - 11:03 AM
of course i understand the difference, and i realize you know what a work plane is, however other people reading this may not quite be so familiar with CAD systems, hence i tried to explain it slightly
anyway all im trying to say is dont read anything into the coordinate or work planes that are shown in the pictures
anyway this is really just splitting hairs as im currently the only person who is working on these cad files so whatever i find easiest to work with is the method ill use
#18 mak790
mak790
    Member
  • Members
  • PipPipPip
  • 154 posts
Posted 17 June 2009 - 01:34 PM
Steven
Check this out, here is a long thread about different type of programs which you can use in design process, some examples, links, prices, availability for no commercial and commercial usage, etc.
http://www.homebuilt...do-you-use.html
Marc is that a common practice for companies such Boeing, Airbus etc , I've never heard about it (but I have much more common with Mechanical rather than Aeronautical Engineering), the only program which I know with similar type of coordinates system is Catia, all others like Solidworks, Inventor, Femap etc use "standard system" of course you can change it.
Seb
#19 Marc Zeitlin
Marc Zeitlin
  • Verified Members
  • 1,011 posts
  • Marc J. Zeitlin
Posted 17 June 2009 - 03:31 PM
Yes. That GCS is the convention in the business. Using a common GCS with common data (plural of datum) allows primes and subs to share CAD/FEA data and models easily without having to do any spatial transformations.
The GCS is not dependent upon what CAD system is being used (I've used Catia, Pro-E, Solidworks, IDEAS, Onespace, etc.). It's a function of how the person using it sets up the part/assembly models during the modeling process. Since it's just as easy to do it right as to do it wrong, there's no excuse for using something that other folks will have to massage in order to use and share appropriately. Standard (in this case, anyway) is better than better (or just different).
My $0.02.
#20 mak790
mak790
    Member
  • Members
  • PipPipPip
  • 154 posts
Posted 17 June 2009 - 04:12 PM
I understand what you mean, of course there is a function of sets up during creating parts, making assemblies, etc , I probably use wrong words I meant that usually Y-axis goes up (like in Solidworks pic1 and Femap pic2 for example), and in Catia pic3 for example Z-axis goes up, but of course it doesn't mean anything, it's up to how you are going to set it up.
Thanks
Seb
btw I took that Catia screen from the internet, because there is no demo/student version of Catia so I don't have that program at home.
Stats
