Phil Kriley Posted April 29, 2009 Share Posted April 29, 2009 I feel kinda silly asking this, but to build the wings, do I go through all of Chapter 19 twice? I've read through it a few times and didn't see any place where it said to stop and go back and build the left wing. Are there no differences between the two, other than being a mirror image? I guess that's good. I guess I just reverse the order of the jigs and go - is that it? I'm terrible at turning things around in my head, I guess... Quote Phil Kriley Cozy #1460 Chapter 13 - nose Right wing done - working on right winglet. Link to comment Share on other sites More sharing options...
Lynn Erickson Posted April 29, 2009 Share Posted April 29, 2009 I feel kinda silly asking this, but to build the wings, do I go through all of Chapter 19 twice? I've read through it a few times and didn't see any place where it said to stop and go back and build the left wing. Are there no differences between the two, other than being a mirror image? I guess that's good. I guess I just reverse the order of the jigs and go - is that it? I'm terrible at turning things around in my head, I guess... yes that is correct you do need a left and a right wing. funny as it may seem there have been people that hot wired two wings for the same side. I build mine at the same time. it saved time on set up for each step but you do need two sets of jigs. and two tables. Quote Evolultion Eze RG -a two place side by side-200 Knots on 200 HP. A&P / pilot for over 30 years Link to comment Share on other sites More sharing options...
jpolenek Posted April 30, 2009 Share Posted April 30, 2009 The way the plans are written, you do the right wing first to the end of Ch19, and then start the chapter all over again for the left wing. As Lynn Erickson points out, doing both wings simultaneously would require two tables, two sets of jigs, etc. Another option is to flip-flop between right and left wing as you work through the chapter, which is what I did. This means that you do one wing to a certain point (preferably the right one since the plans are written for the right), put it aside and do the next wing to the same point. Then continue with the right again, etc. My initial reason for doing this was to reduce the cost of mandatory inspections (Canada) by having the shear webs for both wings and the canard complete at the same time. An advantage of this method, which I did not anticipate, was that it enabled me to achieve more consistent jigging, methodology, etc. between right and left because the techniques and tricks were fresh in my mind. Some parts that did not require extensive jigging could still be done at the same time for both wings. (e.g. wire cutting, wing attachment depressions, etc.). This is probably not as big a deal if you can complete a wing in its entirety within a short period of time so you can remember it all for the other side, but if you're on the 10- to 15-year plan like me, a lot of time could go by between one wing and the next. Joe Polenek Quote Joe Cozy Mk IV #1550 Link to comment Share on other sites More sharing options...
TMann Posted April 30, 2009 Share Posted April 30, 2009 I was getting ready to start my wings and it turns out that all of the gloves I just got from Aircraft Spruce are all for the left hand. Now what?????? Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
steve Posted April 30, 2009 Share Posted April 30, 2009 at some stage there is a mis print and it shows the left wing (dont be fooled) Quote Steve M. Parkins Link to comment Share on other sites More sharing options...
Jerry Schneider Posted April 30, 2009 Share Posted April 30, 2009 I was getting ready to start my wings and it turns out that all of the gloves I just got from Aircraft Spruce are all for the left hand. Now what?????? When donning the right, use a mirror. Quote "I run with scissors." Cozy MKIV N85TT Phase One Testing http://home.earthlink.net/~jerskip Link to comment Share on other sites More sharing options...
Phil Kriley Posted April 30, 2009 Author Share Posted April 30, 2009 Thanks for all the replies - even the silly ones! I ordered all the stuff from AS&S and the Cozy Girrls needed for the wings yesterday. Gonna work on rearranging my shop tonight and making some storage areas for the canard and CS. It's clear the wings will not be finished this summer as I had hoped, with some builders reporting over 300 hours for the chapter. But when they are finished it will surely be an accomplishment! Quote Phil Kriley Cozy #1460 Chapter 13 - nose Right wing done - working on right winglet. Link to comment Share on other sites More sharing options...
Big Steve Posted April 30, 2009 Share Posted April 30, 2009 Phil: I am also working on my wings I have cut the foam cores for the right wing. Will start on the left pretty quick. STeve Quote Steve Harmon Lovin Life in Idaho Cozy IV Plans #1466 N232CZ http://websites.expercraft.com/bigsteve/ Working on Chapter 19,21 Link to comment Share on other sites More sharing options...
mfryer Posted May 1, 2009 Share Posted May 1, 2009 I was getting ready to start my wings and it turns out that all of the gloves I just got from Aircraft Spruce are all for the left hand. Now what?????? I will trade you for half of mine. They sent me only rights. Quote Link to comment Share on other sites More sharing options...
TMann Posted May 1, 2009 Share Posted May 1, 2009 I will trade you for half of mine. They sent me only rights.Oh .... sure! Now you come up with that ...... after I spend most of the evening turning half of them inside out! Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted May 1, 2009 Share Posted May 1, 2009 Spruce got them cheap from Proctology Supply, mostly right handed Dr's you know? ...Chrissi Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
TMann Posted May 1, 2009 Share Posted May 1, 2009 Spruce got them cheap from Proctology Supply, mostly right handed Dr's you know? ...Chrissi www.TheProctRecycler.com has them at about 1/3 of the price but you have to turn them inside out to avoid contaminating the layup. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Cozy Girrrl Posted May 1, 2009 Share Posted May 1, 2009 www.TheProctRecycler.com has them at about 1/3 of the price but you have to turn them inside out to avoid contaminating the layup.I won't be shaking hands with you:p ...Chrissi Quote CG Products www.CozyGirrrl.com Cozy Mk-IV RG 13B Turbo Link to comment Share on other sites More sharing options...
Phil Kriley Posted May 1, 2009 Author Share Posted May 1, 2009 Phil: I am also working on my wings I have cut the foam cores for the right wing. Will start on the left pretty quick. STeve I bought pre-cut foam cores from Eureka and they really look good. I was afraid I'd make a mess of them. Quote Phil Kriley Cozy #1460 Chapter 13 - nose Right wing done - working on right winglet. Link to comment Share on other sites More sharing options...
