GuinnessGuy74 Posted February 24, 2009 Share Posted February 24, 2009 Just a quick sanity check. I am preparing to glass the fuselage sides and I noticed that despite my best efforts, the upper edge of the foam sides are not "perfect". When I put in a 3/4" board as a spacer, I notice a small gap in the middle, maybe around 1/16th or so. Not much. Now when I flox the upper longerons in, weigh them down and clamp them to the spacers, the tops of the longerons are not going to be flush with the foam. I am pretty sure this is ok, as the goal is to ensure that the longerons are straight and parallel to each other correct? Thanks for the help! Truckin' away over here and loving it! Jim Quote Cozy MKIV #1565 (Chapter 6) Charlotte, NC Link to comment Share on other sites More sharing options...
rickh Posted February 25, 2009 Share Posted February 25, 2009 One man's opinion The longerons need to be straight along the top, mostly for future chapters. As to how much foam is showing, it doesn't make much difference near the front, but does at the aft end. The front get's pretty well whacked off when you contour the sides. Aft needs to be flush. The bottom triangular longerons are located from the top longeron. The front half can be a tad shy of the foam, not so in the aft. If anything I would have run my aft foams 1/8" longer. I think Rick Maddy has a good sketch of what might happen at the aft foam. www.maddyhome.com/ I think I have a fair writeup on my site too. Rick Quote Rick Hall; MK-IV plans #1477; cozy.zggtr.org Build status: 1-7, bits of 8-9, 10, 14 done! Working on engine/prop/avionics. Link to comment Share on other sites More sharing options...
GuinnessGuy74 Posted February 25, 2009 Author Share Posted February 25, 2009 Rick, Thanks for the reply. I figured out my problem and it turns out, there is none! I appreciate the help. Great Website! Jim Quote Cozy MKIV #1565 (Chapter 6) Charlotte, NC Link to comment Share on other sites More sharing options...
