wolf. Posted June 2, 2008 Share Posted June 2, 2008 I have a Long with a O-290, since a while every now and then the Oil P drops to zero or below 10psi then comes up again and so forth, if the engine is running for 20 min or more it happens less frequently. I have the non adjustable cage type relief valve. I cleaned the valve replaced the sphere and the spring and it worked for 3h flight now it does it again. Any ideas what the problem could be?? (zero Oil P makes me somehow nervous in flight) wolf. Quote Cosy Classic flying (ex LX-ACE) Varieze N39JC rebuilding Link to comment Share on other sites More sharing options...
Drew Swenson Posted June 2, 2008 Share Posted June 2, 2008 try a different gauge hooked directly to your engine to verify whether it is the engine, gauge, or wiring. Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted June 2, 2008 Share Posted June 2, 2008 The first thing to suspect is the sender, especially the electrical ground to the sender. And senders themselves are fragile--there is a little arm in there rubbing on a coil of copper wire. I think an O-290 is like an O-320. The oil pressure system is so simple in these engines that there is almost no way you can have real zero oil pressure without some sort of massive leak/catestrophic failure. I had high oil pressure readings once. After days of fretting over it, it was the sender. -Kent Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
wolf. Posted June 3, 2008 Author Share Posted June 3, 2008 I have had the same problem with a completely different set up. I had an old sender and a westach instrument, now I have a new sender and an EFIS. But I'lll still try changing the sender. wolf. Quote Cosy Classic flying (ex LX-ACE) Varieze N39JC rebuilding Link to comment Share on other sites More sharing options...
dirtdox Posted June 3, 2008 Share Posted June 3, 2008 I had a oil pressure gauge(automotive) do this. It turned out to be a loose connection at the sending unit. Quote Link to comment Share on other sites More sharing options...
