rnbraud Posted March 21, 2008 Share Posted March 21, 2008 I am planning to upgrade the bolts in my Dennis Oelman rudder pedals to taper pins. Now, what about the "thru bolts" that form the bearing at the ends of the pedals near the fuselage sides? Should they be upgraded to AN4 hardware? Or are the AN3 bolts sufficient? Also, the CS-13. I assume they are steel and not aluminum. Duh. Anyone have the specs on the CS-13? I made some out of aluminum for aligning things, but will need steel versions of them later. Thanks. Quote Link to comment Share on other sites More sharing options...
rnbraud Posted March 22, 2008 Author Share Posted March 22, 2008 Never mind I found it. Page 8 Chapter 13. But the description of CS-13 was a diagram, not in the text where I was looking. I am embarrassed, but relieved to have found it. Later. Quote Link to comment Share on other sites More sharing options...
Big Steve Posted March 22, 2008 Share Posted March 22, 2008 Isn't putting taper pins in the rudder pedals kind of over kill and maybe a little bit heavy? I can see putting them in the control system for the ailerons to stiffen things up a bit but in the rudder pedals you would not even notice a bit of slack. Just my .02 STeve Quote Steve Harmon Lovin Life in Idaho Cozy IV Plans #1466 N232CZ http://websites.expercraft.com/bigsteve/ Working on Chapter 19,21 Link to comment Share on other sites More sharing options...
argoldman Posted March 22, 2008 Share Posted March 22, 2008 Isn't putting taper pins in the rudder pedals kind of over kill and maybe a little bit heavy? I can see putting them in the control system for the ailerons to stiffen things up a bit but in the rudder pedals you would not even notice a bit of slack. Just my .02 STeve Anything more than put into the prototype is potentially overkill, after all it "works" in the prototype. However the prototype is not perfect and there are a plethora of improvements. It is always important to eliminate slop from the control system!! Now let's look at the forces on the various components. The force on the aileron torque tubes are minor compared to the forces on the rudder torque tubes (those that connect the right and left rudder pedals together (in the cozy). If it were only the necessity to pull the rudders outward, the force is small, but don't forget that those torque tubes transmit the force to the master cylinders, a force which is significant. If I had to decide between the two, I would (and will) do the rudders. Quote I Canardly contain myself! Rich Link to comment Share on other sites More sharing options...
Big Steve Posted March 22, 2008 Share Posted March 22, 2008 I have made my rudder pedals with bolts. They have no play so I will not be using tapered pins. I have a mill and My holes are very accurate. I still think tapered pins in the rudders is over kill and very unnecessary. STeve Quote Steve Harmon Lovin Life in Idaho Cozy IV Plans #1466 N232CZ http://websites.expercraft.com/bigsteve/ Working on Chapter 19,21 Link to comment Share on other sites More sharing options...
soloflight Posted March 22, 2008 Share Posted March 22, 2008 Wow! I can't believe the cost of taper pins from ACS. Over $5 per pin. Quote Link to comment Share on other sites More sharing options...
Remi Khu Posted March 22, 2008 Share Posted March 22, 2008 Wow! I can't believe the cost of taper pins from ACS. Over $5 per pin. Yes, multiply that by 8 pins for the control tubes. Don't forget about the castellated nuts, special washers, and cotter pins. You will also need a taper reaming bit. The outcome is fantastic, well worth the expense IMO. Besides, it's pittance relative to other components. Taper pins for the rudder pedals is a great idea, I'll have to remember that when I install my Oelman's. Quote Remi Khu Cozy Mk IV Plan #1336 Link to comment Share on other sites More sharing options...
