Long-ez Control Systems
At Rough River we previewed our new version of the Long-ez control system.
Features:
-complete from elevator rod end to the firewall bellcrank (except universal)
-all hardware and fasteners included
-Cozy Mk-IV type stick grip forks.
-sealed ball bearings support the torque tube in 3 places.
-all aluminum parts are alodined or anodized.
-all steel parts are cadmium plated.
This assembly is available custom built to size or with tubes up to 6" longer for custom fit to longer fuselages.
The hardware and instructions make this easy for both new builds and retrofits.
CG Products
www.CozyGirrrl.com
Cozy Mk-IV RG 13B Turbo
The firewall ball bearing assembly is a very easy retrofit.
-fill bronze bushing with micro.
-drill a 1/4" diameter hole though michro in center.
-use typical hardware store type 1 1/2" diameter hole saw with 1/4" diameter drill arbor to drill out bronze bushing and make new hole.
-assemble bearing on tube and flox ribbed bearing holder in place in firewall.
Bearing is retained with an e-ring.
CG Products
www.CozyGirrrl.com
  • 7 months later...
I got my control system from CG Products and it is really smooth. I used their firewall bearing also. It can not be compared to the standard Long installation...it's far superior. My installation uses taper pins instead of bolts. They take the rest of the slop out of the system.
