sphericalone Posted December 2, 2006 Share Posted December 2, 2006 this is a rc mock up i wanted to fly it for real but it might be too heavy:mad: Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted December 2, 2006 Share Posted December 2, 2006 Missing a picture? Since that was your first post, you may not have been able to add a pic, but should be fine now. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
sphericalone Posted December 3, 2006 Author Share Posted December 3, 2006 this is a rc mock up i wanted to fly it for real but it might be too heavy:mad:the small depron model flies i m probably going to be told to go to another forum for this but before you get your shorts twisted i should say i am really interested in canard designs because of the stability but i have a tendancy to tweak it a bit sometimes just to see how the various factors involved react differently to new environments.So I moved up to kit canards and continue to learn about all the fun involved in building one as well as expense and time Quote Link to comment Share on other sites More sharing options...
sphericalone Posted January 19, 2007 Author Share Posted January 19, 2007 Thanks to this forum I'm learning where to get everything I need to get started. Just a note on the low pressure vaccuum bagging its the best thing ever. Quote Link to comment Share on other sites More sharing options...
sphericalone Posted February 23, 2007 Author Share Posted February 23, 2007 This is how it works.In one half of the sphere is a motor and prop.In the other half is nothing but an exit port.This portion rotates 180 degrees to vector thrust for transition to horizontal from vertical.As you can see from my model they are placed on either side of the craft and a small one in the tail.It's a canard hybrid vtol. Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted February 23, 2007 Share Posted February 23, 2007 Interesting... how about a larger picture? Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
sphericalone Posted February 26, 2007 Author Share Posted February 26, 2007 yes there is a larger view at rc groups sphericalone go to sphericalone at rc groups I posted picture there because it wont post here it's too large.sorry:sad: Quote Link to comment Share on other sites More sharing options...
sphericalone Posted February 26, 2007 Author Share Posted February 26, 2007 I'll try posting a photo here that givew more detail but it may not work Quote Link to comment Share on other sites More sharing options...
--D-- Posted February 27, 2007 Share Posted February 27, 2007 I looked at the diagram on your blog and also read that you are planning on using helium (blimp) for lift. Why not go with a ducted fan instead of the ball for vectored thrust? Less swept volume, proven design/physics, easier to manufacture/articulate, etc. Just curious. Regardless, it's interesting work! Hope to see videos some day! D Quote Link to comment Share on other sites More sharing options...
sphericalone Posted February 28, 2007 Author Share Posted February 28, 2007 The reason for using the ball is that it can act as a gimbal .Actually only half of the ball is used.,but it's that half that is used that acts as the "duct" .In using this shape I get more space which means I get to use a bigger prop which translates into more thrust.By connecting to it's other half and by making that other half moveable I eliminate weight by not having to use extra hardware for a gimbal set up.If I use ducted fans I have to put it on a gimbal and the props are so small there"s not enough thrust.Helium doe'snt really provide much lift unless you have a large bladder,but I found out that even an air filled bladder is ok too.I'm creating an airfoil that uses this pressure to make it rigid over 95% of its area the rest is rudder,elevon and hardware.The entire idea got started by trying to find a way to hover longer to take photos of the rain forest.Usually a hot air balloon does this job,but I like the idea of being able to get out of there quicker when it starts to rain. Quote Link to comment Share on other sites More sharing options...
CP Tomes Posted February 28, 2007 Share Posted February 28, 2007 The reason for using the ball is that it can act as a gimbal .Actually only half of the ball is used.,but it's that half that is used that acts as the "duct" .In using this shape I get more space which means I get to use a bigger prop which translates into more thrust.By connecting to it's other half and by making that other half moveable I eliminate weight by not having to use extra hardware for a gimbal set up.If I use ducted fans I have to put it on a gimbal and the props are so small there"s not enough thrust.Helium doe'snt really provide much lift unless you have a large bladder,but I found out that even an air filled bladder is ok too.I'm creating an airfoil that uses this pressure to make it rigid over 95% of its area the rest is rudder,elevon and hardware.The entire idea got started by trying to find a way to hover longer to take photos of the rain forest.Usually a hot air balloon does this job,but I like the idea of being able to get out of there quicker when it starts to rain. If I'm reading this right, you're going to run the motor 100% of the time to pressurize the bladder? Going to run out of battery, fast, that way. Quote Link to comment Share on other sites More sharing options...
sphericalone Posted March 11, 2007 Author Share Posted March 11, 2007 Negative, there is no need to have a motor to pressurize the bladder.The bladder is inside the kite sail.So it's sort of like a kite-blimp.go to www.livevideo.com/sphericalone to see the concepts involved.The whole thing could have a canard configuration.The spherical looking things are simply prop guards.The spherical shape would allow for a shroud to open and close on the bottom half of the prop guards to distribute airflow in the desired direction.I have'nt built the shrouds yet.I'm constructing mock up models for aerodynamic tests,so far they glide very well without motors.(or helium) but I still want to lighten the load by incorporating the He bladder inside the kite sail this will help it hover and take the strain off the motors in this mode. Quote Link to comment Share on other sites More sharing options...
sphericalone Posted November 2, 2007 Author Share Posted November 2, 2007 Additional info and design update Quote Link to comment Share on other sites More sharing options...
