gupri Posted October 27, 2006 Share Posted October 27, 2006 This is just a thought, which should work. I realise, that the Velocity has currently NO flaps. BUT - if the canards had control surfaces linked proportionately to flaps, this should increase climb, decrease stall speed and therefore shorten roll-out. This system is used (in a much more complicated way) on the Swedish SAAB JAS-39 Gripen fighter and allows exceptional climb, whilst the aircraft is at a horizontal flying position, which allows a better view at the same time. The whole system could be as simple as being worked with a single lever, working with push-pull rods. This should be a relatively easy modification. What are your thoughts on this? Quote Link to comment Share on other sites More sharing options...
Jon Matcho Posted October 28, 2006 Share Posted October 28, 2006 Research the story of the Beech Starship for how Burt was required to install flaps, which he strongly opposed. You could do it, but it's no simple feat. The issue is that flaps would cause the nose to pitch down, and at that moment (pun intended) you would need more lift from the canard. Personally, I don't see how it's worth the engineering at all, but am not arguing that the engineering COULD be done. Get ready for Marc Z. to answer this question. You'll wish you didn't wake up today. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
Nathan Gifford Posted October 28, 2006 Share Posted October 28, 2006 It also complicates construction quite a bit. The other problem is that you will need higher nose position. Not a problem for a tractor aircraft since the prop is in the front. On pushers the prop is moved closer to the runway...not what you would want. Another thing that will shorten takeoff roll is a constant speed propellor. Quote Nathan Gifford Tickfaw, LA USA Cozy Mk IV Plans Set 1330 Better still --> Now at CH 9 Link to comment Share on other sites More sharing options...
rpellicciotti Posted October 28, 2006 Share Posted October 28, 2006 It also complicates construction quite a bit. The other problem is that you will need higher nose position. Not a problem for a tractor aircraft since the prop is in the front. On pushers the prop is moved closer to the runway...not what you would want. Another thing that will shorten takeoff roll is a constant speed propellor. Nathan, you are on to the key thing here. If shorter take-off and landing are required, a constant speed prop is the best way to get it. Take off distances will be considerably less and the drag of the prop in flat pitch will allow steep approaches and shorter roll out after touch down. The main thing is that the constant speed props add about 45 pounds to the aft end of the airplane. This is a problem for the Long-EZ and perhaps the Cozy. The subject airplane, Velocity, is designed to accomodate the constant speed prop. For proof that flaps do not lower the landing speed of a typical canard airplane, the above mentioned Starship had virtually the same stall speed with flaps up or down. Why? Because the reserve lift available from the canard is used up compensating for the pitch down force from the flaps on the main wing. There is little lift left over for actually flying at a slower speed (amateur aerodynamic theory here). This is not to say that a airplane with a canard cannot be STOL, look at the Grizzly. I am just agreeing that for the Vari/Long/Cozy/Velocity/Starship configuration of canard aircraft, flaps don't help. Quote Rick Pellicciotti Belle Aire Aviation, Inc. http://www.belleaireaviation.com Link to comment Share on other sites More sharing options...
bferrell Posted October 28, 2006 Share Posted October 28, 2006 The other thing you can do is add vortex generators on both wings to get the T/O and landing speeds down. I intend to do this, though it's not nearly as pronounced a change as using a CS prop. Brett Quote --- Brett Ferrell Velocity XL/FG Cincinnati, OH http://www.velocityxl.com Link to comment Share on other sites More sharing options...
gupri Posted October 29, 2006 Author Share Posted October 29, 2006 Thank you all for your replies. My main reason for throwing this idea of flaps, LINKED TO CONTROL SURFACES ON THE CANARD, was the very much improved climb. Marc Z. apparently realised that, by not replying. The shorter field performance would only be an added bonus, but only useful in an emergency landing, which hopefully NEVER becomes necessary anyway. Quote Link to comment Share on other sites More sharing options...
Nathan Gifford Posted October 30, 2006 Share Posted October 30, 2006 ...very much improved climb. Marc Z. apparently realised that, by not replying...Possibly, but it is just as likely that he either did not see these posts or wasn't interested in replying on this subject again. Silence in plane building should not be confused with concurrance. Climb performance on Velos and Cozys is pretty darn good as is. A number of flyers I have talked to do not go for all the climb performance their ships can deliver since they get a pretty brisk ascent anyway. They opt for being able to look over the nose. On descents, belly board out and both rudders deployed allows a lot of altitude loss. I realize that what you are attempting to do is get a better rate of climb without having a nose high atttitude. Those kinds of control changes to Velos or anything else, do not come free. The added weight, complexity, and build time may not be worth it on a Velo or Cozy. On a different plane, maybe??? Quote Nathan Gifford Tickfaw, LA USA Cozy Mk IV Plans Set 1330 Better still --> Now at CH 9 Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted October 30, 2006 Share Posted October 30, 2006 Thank you all for your replies. My main reason for throwing this idea of flaps, LINKED TO CONTROL SURFACES ON THE CANARD, was the very much improved climb. Marc Z. apparently realised that, by not replying.Maybe you could list a few planes that recommend flap usage during climb to improve performance. Not soft/short field takeoff, but climb, as you proposed. Then maybe you could explain how you think flaps would work to do this. Don't ever assume that because someone (anyone) doesn't respond to whatever you (or anyone else) say, that they therefore agree with you. The reasons for silence are manifold. In this case, I was at a John Prine concert Friday night, and then at Copperstate since yesterday morning. Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
iwantmycfi Posted November 4, 2006 Share Posted November 4, 2006 Just thinking out loud, but a buddy mentioned that the Boeing 737 almost maintains center of lift on the main wings by having fowler flaps and the forward slats. The end result being lift stays near the middle of the wing. Although this would be way to complicated in terms of return (I think), would this be a way to maintain the center of lift on the main wing of a Velocity and not stall the Canard? Tim Quote Link to comment Share on other sites More sharing options...
Nathan Gifford Posted November 4, 2006 Share Posted November 4, 2006 ...Although this would be way to complicated in terms of return...Don't forget the weight too. Keeping the weight down might give you better performance than adding high lift devices. Quote Nathan Gifford Tickfaw, LA USA Cozy Mk IV Plans Set 1330 Better still --> Now at CH 9 Link to comment Share on other sites More sharing options...
