Catman Posted October 7, 2006 Share Posted October 7, 2006 Contains the A, B, and C kit featuring molded wings and Canard. The airplane can be seen on my website http://mysite.verizon.net/res09zd0 if you would like to view it. Kit also includes many parts not offered in the kit. The following is a list of many of the parts (but not all) 1.Molded Wings (including flat stock for ribs and spars) 2.Molded Canard (including torque tube, inserts and unassembled hotwired elevators, but does not include hinge points) 3.Fuselage with Main spar, baggage door, longerons, pilot seat bulkhead, landing brake with electric motor; partial controls and landing gear installed. 4.Landing gear – including “A” and “H” arms, Aluminum castings, Matco wheels and brakes). 5.Molded Strakes – including flat stock for ribs. 6.Assortment of aircraft grade nuts, bolts and washers. 7.Hydraulic Cylinders for Main Gear Retract 8.Wilhelmson Nose wheel retract system. 9.Allen Fuel Valve. 10.Hydraulic Lines (it is unknown if they are sufficient to complete project) 11.Hydraulic Fittings (it is unknown if they are sufficient to complete project) 12.Hydraulic Upper and Lower limit switches for hydraulic motor. 13.Hydraulic Dump Valve 14.Brake cylinders 15.Rudder Pedals with slide tubes 16.Canopy Latches 17.Canopy Frames – includes front hinge. Rear hinge has to be fabricated. 18.Special Brake line fittings 19.Instrument Panel (Fitted only) 20.Receivers for ball end bearings for Aileron torque tubes. 21.Pneumatic canopy supports (front and rear) 22.Rod end bearings ¼” (more may be needed to complete the project) 23.Two Throttle Quadrants (pilot’s quadrant installed) 24.Aileron torque tubes with idler arm (installed) 25.Flat stock for consoles and bulkheads. 26.Miscellaneous aluminum flat and tube stock. 27.Miscellaneous hardware. 28.Engine mount for Lycoming IO 540 engine 29.Carbon Fiber cowls for Lycoming IO 540 engine 30.Main Landing gear doors. 31.Front Landing gear doors Link to comment Share on other sites More sharing options...
Kalustian Posted April 22, 2007 Share Posted April 22, 2007 Hello How much are you asking for the Kit..? link is showing a long-ez not your kit. Thanks Link to comment Share on other sites More sharing options...
Kalustian Posted April 23, 2007 Share Posted April 23, 2007 Hello How much are you asking for the Kit..? link is showing a long-ez not your kit. Thanks ...Sorry..I have not seen your " ...my Berkut project but the airplane has been sold." note.. Link to comment Share on other sites More sharing options...
JD Honkonen Posted August 5, 2007 Share Posted August 5, 2007 Contains the A, B, and C kit featuring molded wings and Canard. The airplane can be seen on my website http://mysite.verizon.net/res09zd0 if you would like to view it. Kit also includes many parts not offered in the kit. The following is a list of many of the parts (but not all) 1.Molded Wings (including flat stock for ribs and spars) 2.Molded Canard (including torque tube, inserts and unassembled hotwired elevators, but does not include hinge points) 3.Fuselage with Main spar, baggage door, longerons, pilot seat bulkhead, landing brake with electric motor; partial controls and landing gear installed. 4.Landing gear – including “A” and “H” arms, Aluminum castings, Matco wheels and brakes). 5.Molded Strakes – including flat stock for ribs. 6.Assortment of aircraft grade nuts, bolts and washers. 7.Hydraulic Cylinders for Main Gear Retract 8.Wilhelmson Nose wheel retract system. 9.Allen Fuel Valve. 10.Hydraulic Lines (it is unknown if they are sufficient to complete project) 11.Hydraulic Fittings (it is unknown if they are sufficient to complete project) 12.Hydraulic Upper and Lower limit switches for hydraulic motor. 13.Hydraulic Dump Valve 14.Brake cylinders 15.Rudder Pedals with slide tubes 16.Canopy Latches 17.Canopy Frames – includes front hinge. Rear hinge has to be fabricated. 18.Special Brake line fittings 19.Instrument Panel (Fitted only) 20.Receivers for ball end bearings for Aileron torque tubes. 21.Pneumatic canopy supports (front and rear) 22.Rod end bearings ¼” (more may be needed to complete the project) 23.Two Throttle Quadrants (pilot’s quadrant installed) 24.Aileron torque tubes with idler arm (installed) 25.Flat stock for consoles and bulkheads. 26.Miscellaneous aluminum flat and tube stock. 27.Miscellaneous hardware. 28.Engine mount for Lycoming IO 540 engine 29.Carbon Fiber cowls for Lycoming IO 540 engine 30.Main Landing gear doors. 31.Front Landing gear doors Please contact honkonen57saber@yahoo.com Link to comment Share on other sites More sharing options...
Jon Matcho Posted August 7, 2007 Share Posted August 7, 2007 This project has been sold. Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
